So I changed my front and rear brakes fronts were no problem, the rear brakes on the other hand were a little more difficult. I had a hard time separating the caliper to grease the rod, I had to beat it with a hammer to get them to separate. I got everything apart and greased up and put back together. Took the car for a spin, not sure if they are working or not, I touched one rotor after the drive it was cool the other side was a little warm. And the emergency brake isn't working at all.. any suggestions?? Thanks.. Chris
