The Great NY
- 2004 Mazda Atenza(6)
Why wouldn't it be?
SkyActive 2.0 with HCCI is reportedly in the works.
http://wot.motortrend.com/1401_mazda_skyactiv_2_engines_to_feature_hcci_tech_debut_by_2020.html
Good question, Mazda took it seriously
The gas engines will achieve that extra efficiency with spark plug-less homogeneous charge compression ignition (HCCI) tech.
Read more: http://wot.motortrend.com/1401_mazd...re_hcci_tech_debut_by_2020.html#ixzz3kzXCkvTw
here is why i didnt take that question seriously. HCCI tech is far too costly to implement at a mainstream level. While making a statement saying its in the works, makes things sound good. it does not mean it's going to happen for a number of reasons.
Biggest issue is how hard it is to control an HCCI event. they are quite different than Diesels, although they say they are similar. only similarity is that it doesn't have spark ignition. Really thats where the similarity stops. Diesels work the way they due because the fuel injection can be actively timed by the injectors as fuel is injected into an already compressed air charge (top of the compression stroke almost. With HCCI the fuel and air enter the chamber at the same time, and ignite whenever the pressure and heat reach the proper point. Why is this an issue?
-Cold winters will make it SIGNIFICANTLY harder for the combustion to happen. sometimes not even happening at all. Hot summer days you will get early ignition. Weather temps effect HCCI greatly. Sure, heater and cooler assemblies could be implemented to help these issues, but that adds cost of another microcomputer along with other sensors and etc that are going to need to be added.
Valve actuation also effects HCCI greatly, along with quite a few other things. Also, HCCI due to the way it works operating on lean fuel mixtures, the peak temperatures are much lower than conventional gas and diesel engines. BUT, the low peak temperatures also lead to incomplete burning of fuel, especially near combustion chamber walls which leads to high carbon monoxide and hydrocarbon emissions.
Pre-ignition goes back to what i said about HCCI being hard to control when combustion happens. so pre-ignition will be harder to fight in an HCCI system. Also, although this seems to be where many Mazda is moving towards (doesn't mean i like it) HCCI engines have a small power range which is pretty much restricted to low loads by lean flammability limits and high loads by in-cylinder pressure restrictions
In short the overall complexity and issues fighting against the HCCI process, it will be quite tough to use HCCI engines in a mass produced cost effective way. As they are/will be far more expensive to build, engineer, and maintain than what we are currently using.
Also, Mazda is NOT the first people doing HCCI, GM had a running prototype back like 7-9 years ago i think it was. and there are other companies already attempting it. GM's version was a bit of a hybrid. but guess what, it only got 6 more MPG over the standard 2.2L Ecotec engine it replaced. Not worth the cost IMO. But this is just an educated opinion on my behalf. if they do it, awesome. but i personally dont want it due to all the s*** that can go wrong.
