..........and or gas pump calibration is off. Thought 14.6 was full. Never filled mine more than 14.2 and that was scary on E.
How do y'all get that much gas in ur car? I can barely squeeze 12.6 gallons with it on e for like 5 miles.
used to get ~30 mixed city/hwy on my manual, now (18 months later) its only about 22-24. Have no idea wtf happened! changed plugs, new filters, oil, cleaned maf sensor, cleaned egr, no CEL, tires at 35-38psi, no roof rack, no extra weight, various gas stations, doesn't matter if i shift at 2.5k, or at 4k+. someone suggested to check the o2 sensor which may be a bit off w/o triggering a CEL, but i doubt it'll give me a 30% milage increase! also had an auto p5, which gave about 24 ctiy/hwy mix, 28 when mostly highway.
should have gotten a truck.
'03, 5 Speed - I managed 35.9 mpg on an all highway trip the other weekend. Kept it between 65-70mph and took it easy, used cruise control as much as possible. A/C was on the whole time too. Gas light didn't come on until 465mi.
I was pleasantly surprised.
trey
i believe 30mpg is achieveable with all maint. done and sys fluids. and keeping it under 70 al all time.
HP peak and torque peak and max engine efficiency are all in different places. Peak HP does not = peak mpg.I thought peak hp was around 6k?
I know it means peak power which is where I like to beit looks fast may as well make it go fast. This same thing has been discussed so much. How high or low your rpms are doesn't effect it as much as how much throttle your giving it or areo dynamics on thing that kills these cars is how high off the ground they are. Notice a lot of people in th 30+ range are lowered? I don't have a problem with it all that much but then again I say that looking at my 7- 17 mpg buick atleast the mazda is more consistent. For older cars 30 mpg isn't all that bad
