rar40941's build thread
For right now I am staying with the same wheels and I still need to get my dam door fixed and when I get it looking sexy I will be good. Then I am going to get all the gt spec braces but the front strut and the h brace. Then big break kit and brake lines then. I can do the interor like gutting it get a role bar racing seats seat belts and wheel and quick releace. Shifter and and stud pretty much get it ready to go fast then I will be good to go in a striaght line lol
So you plan on having seats roll cage and harnesses in a pretty much stock car? No need for any of that unless you want to make a slow car look fast
The xxrs aren't to heavy but ya I would like to have all the stuff so when I do make it fast it will be good to go. The only engine mods I have don are my 3 engine mounts still have to do there rear engine mount and intake ,exhaust the radiator hoeses I was thinking about geting a header a test pipe new manifulled and stuff but I want to boost not NA
hey guys i am going to work on my flares again this week i will keep u updated.
and does anyone want the oem wireing for the fog lights 20 plus shipping
Well guys **** my life I just creased my other dam fender I need these dam flares to be don here are some pics
You are having no luck my friend... id say its time to prep your fenders for the flares till you get them on then you won't have that issue...
hey man i need your help! befor you said you pulled ur linkage kit all the way??? i tryed it and my rim is hitting the back it on the frame of the car? help me homie since we have the same rim set up...
rar just raise your car up man, and that wont happen, you obviously cant run that low with that wide a wheel, just be patient and get those flares on there.
and rep, you have no where near the same set up as rar
damn ur right.... i keep thinking i have the same set up werid!! i guess i got some adjusting to do later...
Ya I need get my flares don I hope I can get them don soon. And rep when it hits the frame u have to add spacers that's what I had to do I rubbed on the frame and the metal toobs before I had to add the 15 mm spacer In the rear
Well I fixed the flare I had to pull the s*** out of it and hammer it so I kinda fixed it I can drive with out rubbing lol need to work on the flares to day
Well I fixed the flare I had to pull the s*** out of it and hammer it so I kinda fix it I can drive with out rubbing lol need to work on the flares to day
Did the dent stress the metal, or does it look normal now that it's popped back out?
