When I got this 2007 M5, it was simple: I took the key out of the ignition, the radio turned itself off. Immediately. A few months later (I got it in 2010), it would keep the radio playing for one minute after removing the key. After that minute, the radio would turn off. The display would stay on a couple of seconds longer than that, but not much.
I know other cars do that, but not in the same way. In this case, the radio STAYS on for the full minute, no matter if the doors are opened, closed, or if there's anyone in the van. If I powered off the radio with the on/off/volume knob, it would turn off without issue. No delay.
The buggy thing is that this is a "flexible situation". It will be like this for months on end, and then one day it will return to the immediate "turn off" it did when I bought it. And then back again to the one-minute delay.
I can't figure out why it does this or what triggers it to switch from one state to the next. Any ideas? Ghosts in the machine? Sould I be worried?
thanks in advance.
thanks in advance.
