Ok so il start off with the problem, I was merging into freeway today and when I turned my head back around I saw a quick flash of idiot lights on the dash but I couldn't make out what they were. I continued home and I turned on my turn signal to get off the exit, then my radio just shut off and came back on, along with that I had that quick flash of lights. This just happened today for the first time. I have had a boost gauge installed since Xmas which is tapped into some acc power here the dsc button is.
Other than that I don't think I've messed with any other wires. I have had my car out of balance and had a slight wobble for a month or two, not sure if that is shaking or running some wire. So any help with this issue would be appreciated, I will take apart the dash this weekend to check out wires and investigate.
