Mental Addiction
Banned
As for motors, it depends on what you are looking for.Our motors are a Nascar grade engine build.The block is FULLY machined and deburred.We have the crank Nitrated then micro polished to add strength.Next we machine in a 2nd thrust washer,use ARP main studs,ARP head studs, and Toga tri metal high performance bearings.We only use the best parts, believe in doing it all at once and not cut corners here and their to save money.Some people might say it's over kill.The few hundred dollars saved now might cost you everything if it blows.The piece of mind knowing that you can throw as much power as you want at our motor is worth the few hundred dollars. Good luck with your search and I hope you get what you are wanting.
