race fuel?
SuperSpud
ok, so I was just wandering. I have seen several ppl here talking about using higher octane gas.. 104, 110, etc. can you just do that? I mean, can I go to a speed shop and buy some 104 and put it in my car? no problems? someone explain for me.. and what are the advantages of doing so
besides its not good to mix fuels... they never really mix completely, and you may be sucking in the 110, then hit a bit of the 87 octane, and break somthing.
why would you want to run 104 or 110 anyway? you would only need that if you had like 20 psi then you would have lots of other things to worry about *cough* rods
just make sure you're buying unleaded race fuel as most race fuel has lead in it - ie you'll kill your cat converter in no time.
I have 112 leaded fuel in my car right now. Never got to use it because I snapped an axle. Sometimes I go out and start the car just to smell it. Damn it smells so good.
Unless you have an aftermarket fuel map, your fuel map is not designed for race gas so the only reason to use it would be for turning up the boost...
xelderx said:
You won't get much extra in the way of HP, but VP Motorsport 103 octane smells so good.
you dont gain hp from 104 fuel, as stated above main thing it would do for us is allow us to run more boost without detonation but dont go runnin 20 something or even 20psi.
16-18psi;)
So I know Joe P. dyno'ed his car with race gas but has anyone actually gone to the track with 118? Btw with 16-18 psi.
I might try it once I'll post later if I'm game.
GOTZOOM? said:
lol, cats, are you kidding.:D
bye bye oxygen sensor.
MSP Chris -- So I know Joe P. dyno'ed his car with race gas but has anyone actually gone to the track with 118? Btw with 16-18 psi.
Usually fuels this high are leaded...
the avarage ricer comes up to me and says "dude you better run turbo blue or else your engine is gonna blow up"
So what octane does it become leaded 104?
Ingrexco no offense but most ricers approach people with strobes and neon lights, they are like bugs.
