Questions.. sorry in a hurry!
Speed3Max
I didnt search much but... will 18x9.5 +38 offset and 18X7.5 +42 offset fit on the ms3? all four have 225/40 tires.
-Max
I'm gonna assume you're on stock suspension, sooooo:
1st set of rims won't fit, a bit wide and offest needs to be between 45-52.5mm (maybe 42mm, not sure)
2nd set of rims will fit
You beat me to it.
Maybe with a wide body kit. The second on would fit, however I would highly reccomend going up to 8''. Try to find an offset between 48-53. If you want to go really wide check out my 8.5'' threads as well as buildabongs 17''x9'' setup that he has recently posted.
The 9.5'' might clear in the front with that low offset, I have a feeling it will hit the strut though. With an offset of 42 in the rear even a 225 would probably rub without rolling the fenders. The front fenders might be ok.
