Maybe with a wide body kit. The second on would fit, however I would highly reccomend going up to 8''. Try to find an offset between 48-53. If you want to go really wide check out my 8.5'' threads as well as buildabongs 17''x9'' setup that he has recently posted.
The 9.5'' might clear in the front with that low offset, I have a feeling it will hit the strut though. With an offset of 42 in the rear even a 225 would probably rub without rolling the fenders. The front fenders might be ok.
