questions and info about an rx7 im interested !
03.5 Msp
so i saw and ad for a 1988 rx7 with a 1990 turbo 2 engine said he wanted to add the two back seats that the 2+2 GL came with i think it was , any way he said for 3800 it could be mine but he knows im short on cash so i can do his wifes trucks brakes and some other faovrs to lower the price , ok my questians are what are the turbo codes or facotry numbers and engine numbers so i can be sure it is a 1990 turbo engine that he said it was , also some advice and inputs please : ) thanks
The Map sensor which is a little square sensor on top of the passenger side wheel will say N370 if it is an S4 Tii. The Turbo will also have an extra solenoid on it to control the flow of air through the twin scroll manifold. Don't know for sure though since both of those parts could be used with an S5 block.
info on S4 and S5 ... turbo and Non turbo
ahem ... ok since i HAVE an S5 aka Series 5 Rx7 engine in my 1988 S4 aka Series 4 Gxl Rx7 .. lol.. i believe i can answer this for you the RIGHT way lol
IF he DOES have the S5 turbo engine in the car ... just look at the FRONT rotor housing ... IF You see a big KNOCK Sensor sticking out the side of it right above the Trailing spark plug aka TOP plug... then its an S5 engine .. that and if the Air flow meter is ROUND and has N370 on it and the Boost pressure sensor (mounted on right front strut tower, above airbox area) says N370 then he has the S5 engine in the car ... N370 is S5 ... N318 OR N332 is S4 tii N326 or N327 is Non Turbo stuff ... here is a pic of the Knock Sensor and Air flow meter and Boost Pressor sensors ....
here is the S5 Turbo II air flow meter and Boost Pressure Sensor...
here is the Knock Sensor right above the upper left spark plug (its black and hexagon shaped)
hopefully this will clear up any and all confusions/questions lol
if you need more info feel free to Email me Or IM me at
Mazdaracer4fun@aol.com
this should help , but at the moment i decided not to get teh rx7 , filling that car up will kill me especially since i havent been working ebcuase my knee is busted : /
thanks
Great example of a helpful thread...Good job Guys! (2thumbs)
Keep us updated if you do pick this 7 up in the future...:D
