Psycho_Maz
- 2008.5 MS3 GT - MGM
I have a MS3 GT with bose. I am just looking to add some good clean bass for rock and some rap. I have the factory bose HU, Infinity reference 6x8 in the front which brightens the system up a bit, and stock bose in the rear. I want to keep it as stock as possible, i.e. I am not looking to replace the factory amp or tear out factory subwoofer. I don't plan on switching out the rear speakers at all. I plan on doing the "standard" subwoofer/amp installation from previous "how to" posts. (I plan on tapping into the pre-amp bose signal and running the speaker line to the hatch for installing the sub box and amp.)
I found a 10" JL Powerwedge, Sealed (CS110RG-W1V2), 4ohm, 50-300rms, 600watt max... for 149.00 shipped from sonicelectronix
http://www.sonicelectronix.com/item_7416_JL+Audio+CS110RG-W1v2.html
-the 12" is 40.00 more at 189.00
I was thinking of one of the following amps to push the powerwedge...
1) Alpine MRP-M500 RMS 300x1 @ 4 ohms - 149.00 @ dealercostcaraudio.com
http://www.dealercostcaraudio.com/MRP-M500.aspx
or
2)Kicker ZX300.1 150RMSx1 @ 4 ohms - 119.00 @dealercostcaraudio.com
http://www.dealercostcaraudio.com/08ZX300.1.aspx
Alpine is supposed to be the better amp, but is the Alpine too much power (RMS) for this speaker? The only thing I like about the kicker is it has a remote I can run up to the driver seat and is a tad cheaper, but lower power. Both have speaker level inputs which is nice for the install. The Alpine has more flexibility as far as low pass crossover and other features.
So my question is:
1) which amp to push the 10" JL powerwedge? Is the Alpine too much power?
2) Would you suggest I include a ground loop isolator when I install this?
thanks for the inputs in advance
or
So my question is:
