Ok guys,
From reading on this board you are obviously the most informed and educated about turbo'ing our cars.
Now, I have the BEGI kit sitting 2 feet next to me waiting for installation next week. As you know, the kit is still having it's feul system figured out. Right now the kit is set to 6psi, and runs well (maybe a little rich, but that all depends).:mad:
The kit was actually built to run at 8psi, but since then has been deemed 'unsafe" to run at that high of boost. The first fix floating around was to install the aux pump to get the feul psi we needed to run at 8psi.
Now FM and Corky have slowed down a bit and started testing many other ways of dealing with this issue. Corky told me to contact him in a month for much more info. I have no idea if he's planning on sending out the required parts to enable the kit to properly funtion at 8psi or not-once the come to a conclusion.
My question to you guys is:
How would YOU deal with this issue? What would you do/and/or buy to get this kit running at 8psi? Please keep in mind cost, and possible problems that might arrise when the task is at hand.
Basically-what's the most cost effective/efficient way of getting past this feul issue to get to 8psi?
