Question about strange issue that almost left me locked out
So.....
I have the start-x remote start installed in my 2020 CX9 and recently I drove to a store and left the car engine running, got out, closed the door and attempted to lock the car with the fob lock button so I can run into the store quick and come right back in 2 mins. ( I did not use the remote start at all) To my surprise it did lock the car with engine still running and I went into the store. When I came out 2 minutes later, I attempted to unlock the car with the fob unlock button and there was no response to the car. I've been attempted to press the button on the handle to unlock and again there was no response to the car. Every door was locked except for the hatch which opened with the button on the bottom of the hatch itself. Keyfob buttons were dead ( but lit up) and so was button on handle. I had to crawl in through the back hatch and open the door to get back in normally. WTAF.
Additionally, I was able to reproduce this several times by being inside the car, starting it, using the fob lock button to lock the doors while inside and attempting to unlock using the fob. The unlock button on the fob did nothing. The button on the handle outside did nothing( window was rolled down). AND the inside lock/unlock button on the door itself ONLY worked one direction to lock. There was no response when pushing it to unlock. I then shut the car off and restarted and now the inside buttons worked again. I attempted to duplicate again and again and it happened the same every time.
Does anyone with or without the remote start X installed have this issue? If stock vehicle, can you lock the door with the fob button with engine running?
My fob battery is new as well as my 12v battery. I'm trying to diagnose if this issue is a bad body control module or if the aftermarket remote start has anything to do with the vehicle behavior before taking it in to the dealer under warranty (extended)
This is really dangerous and unacceptable in any vehicle.
Thanks all for your insight!!
Greg
Hey can anyone please test trying to lock their car with the keyfob with engine running to see if it actually locks or unlocks with the fob or door handle? Also if you have the start-x remote starter installed and try to do the same and see what happens?
I just want to know if this is a problem with the car or has anything to do with the remote starter.
Thanks guys/gals
Upvote 0
Not a CX-9 owner but have had several CX-5's which I believe share architecture.
I cannot lock the car with the fob or the exterior button while the engine is running.
If I wanted to lock the car but keep it running, it has to be done from the door button on the inside.
And as soon as I get out, it will start fast beeping once it notices the fob is leaving the proximity of the car.
Upvote 0
Thank you! My wife's car is a 2021 CX-5 and she cannot lock the door with the fob with the engine running either.
I'm really curious if there is a problem with the body control module or if the start-x is the problem. The only way to tell is if I uninstall it but then I won't know if the start-x is defective or not if the car goes back to normal after uninstall. I emailed the company to see if they know anything about this.
Will post back once I get an answer. Hoping someone with a start -x installed could chime in.
Upvote 0
Update :
Called start-x and explained the problem I'm having. Was told that the start-x module should not have anything to do with the car locking with the engine running and is just an auxillary device which does not have the factory lock/ unlock function go through it and they haven't had anyone have a problem like this. They suggested I unplug the module and test without it.
So...
I unplugged start-x module from the end of the harness where the module plugs in and left the t- harness attached to under steering column. Result was the car behaved normally again and does not allow you to lock the doors with the fob with the engine running!
Put in another support call to start-x. Waiting for reply.
Seems like the start x module is malfunctioning and went bad if they are telling me it is an isolated device.
Upvote 0
