question about accesstuner
What is the difference between ign table- low throttle/CL (knocking) and ign table- low throttle/CL (no knocking).
My problem is : I have knock retard at low throttle and I want to reduce my timing. So, in which table I have to do it.
If I have knock retard at low throttle, it is a good idea to reduce the timing in the good range.
absolute load exemple 0,69 means 69 % calculated load? yes or no
My mod are cp-e nano, cp-e turbo inlet, itv 22, cp-e fmic, hks ssqv (recir) and ap stage 1 sf fmic 91 with 94 octane
In third gear, it is normal my boost is 17.69psi at 4600 rpm and drop to 13.5psi at 6440 rpm.
In fourth gear, 18.27psi at 5000 rpm and drop to 13.92psi.
Why my throttle position is only 73 % max open at wot.
Thanks
