My 2002 Protege5 is no longer able to easily make it up even the slightest of hills. It doesn't miss, nor generate an error message, just slows forcing a downshift. I'm the original owner, and it has 75K miles. It's a 5-speed. The problem started after I tried platinum plugs. I switched back to regular ones, but the problem persists. I was going to change ignition coil and wires, but was told if they were the problem I'd have an error code, and that fuel filter (sock) probably is clogged, which the computer would not notice. But I've seen no other discussions of this problem. I appreciate all suggestions, especially knowledgeable ones 8^). Thanks!
