Protege03ak46's Build Thread
I've got plans. 3" mandrel bent is on it's way from summitracing. Shall be polished when it gets here.
mandrel bent what? stainless?
thats really the only thing i would spend money on if i was doing a tip like that, i want to do a tip similar, but dual outlet and angled to the side
like the aspec blast pipes that the 240's run
Its called bozo pipe and yes, stainless. I think it would look funny if blast pipes wernt under axle.
No, there are actual Aspec tips called Blast Pipes that are very common with the 240 crowd. lol
Im talking about mine...
I know what blast pipes are. blast pipes are just a description of what they are. A-Spec just made a product called "blast pipes"
soooo whats up with the bmw? and is the new tip gonna be single pipe tip or dual exit?
need to put on one of these....
On my way home from my friends today my car felt really boggy and slow. I came to the bottom of a hill and noticed my car died. I didn't really think much of it untill it a mile down the road. In the next 2 miles from, It died close to 15 times. I m driving normally and the rpm's would fall. I smashed and it would slowly pick back up. At one point I stood on the road for 10 minuets, trying to get it going. It finally started and limped home.i really didn't have the time to look at as I had to goto work. I'm almost 100% sure the MAF got wet or went bad.
Cleaned the MAF, didnt help. Cant find a vac leak. Its throwing a code, but i dont have access to a reader. I do know its running crazy rich. Anyone have any pointers on what it could be?
^ what he said.
scan it if you can.. i'm guessing it's a fueling issue.. possibly injectors. but with this kind of issue it can be so many things.
Code was a faulty maf/ low voltage from maf. Replace maf today still doing it. Idk what the hell is going on. May be EGR? Faulty injectors? But if it was injectors wouldn't the problem got worse overtime, not all of a suden?
Check your under hood fuse box.
I had a relay come loose and the car just died. Pushed it back in, it started up, and ran fine.
LOL, thats exactly what happened. discovered it when i was doing an inspection... I felt like a noob
