Protege Wish List (Vendors click here)
give it up or die hehe
no seriously what is a "Ventura tray" if its that flat paneling that goes under your car i seriously might be interested in one. im trying to get my car as aerodynamic as possible without ricing it all up
paulmp3 said:
this winter if i can give my car up for two weeks we will have one.
btw, nice pic of your car. looks sick.
DOOOOO ITTTTT!!!!!!
you shall be loved by millions of protege drivers, or maybe just like 3.
please do it.
MP3skaterNC said:
DOOOOO ITTTTT!!!!!!
please do it.
I will discuss it with him this in two weeks when i see him. he mentioned b4 if there was interest he could get a mold made of the prototype and have them made in cast aluminium. I only spoke briefly about it with him, he said there is a lot of testing b4 it would be ready
here is a pic of his intake mani for his dart. I would think the runners would be bigger though :confused: im not sure if it would look like this or not? i have seen pics of custom mani's in mags but never actually saw on in person.
I will talk to him and find out. i think he might need the car. I will discuss everything in depth we i see him on the 4th.
Do you guys know any good specs? bevis wanna do some engineering to disign the best flowing intake??
I will get back to you guys, i really would like one myself.
he is gonna be making one for biknman's 1.6 soon, that car is bad ass.
someone had a question long ago in the post about a carbon hood and cam gears- just tryin' to help em' out
We should have the intake manifold by jan or feburary if i can give my car up.
Kooldino said:
I definitely think 5whp is possible out of a P5 from a chip. It could be accomplished by advancing the timing and leaning out the fuel alone. 5whp isn't much...
I agree- has anyone tried the jet chip in our car? If the mp3 ecu can add 10whp, wouldn't you think that sending your ecu to jet could accomplish the same thing for around $300? They do advertise that they work with our cars....
People need to stop thinking that the MP3 ECU will add ten horsepower.
IT DOESN'T!
so how do they get the extra hp out of the mp3- I really thought that it was by leaning out the a/f and advancing the timing?
Nope...
The exhaust and intake manifold make a difference as well. And they don't lean anything out, the MP3 runs pig rich just like all the other Proteges. My tail pipe will attest to that.
The ECU does play a roll, but it is not the only piece of the puzzle that makes the 10 hp.
Look at the dyno's of my car on Flyin' Protege's web site. We ran my ECU and got stock figures. We put the Protege 5 ECU in my MP3 and got less two hp and up one torque...Where is all of the extra ten at? Not in the ECU...
I'm confused. I see alot of people griping about the transmission. What is the problem with the stock trans in your cars? I have run 2 of them in the rally car and every time we rebuild it, we are amazed that there is no synchro wear and the gears look good. After 2.5 years of rallying, I have a bit of pitting on the ring and pinion, but I am using the Emco r&p anyway. All this on boxes that get 200+ hp put through them, get downshifted often with no clutch, and get shock loads up the yingyang when landing from jumps, etc.
Also, somebody wanted racing axles. The stock axles are extremely strong. I haven't broken one except when I exploded a wheel on stage. The hard outer boots kinda suck, but not worth getting my undies in a twist. Again, if they take the shock loads of full power at full lock and full power on pavement landings on jumps at full droop, they should be more than adequate for your car until you are seeing 220+...and even then I think they will hang in there.
Intake manifolds and T-bodys can be flowed, bored, and reworked/new plate by a reputable cylinder head shop...open the yellow pages. My rally motors all use stock based parts.
The things you N/A guys need to make power are CAMS, COMPRESSION, and ENGINE MAPS (ECU). That will get you a big jump. Beyond that it is real work with changing valve sizes, etc. Again, a reputable cyl. head shop should be able to help you with it, but if the ECU wont give you the fuel or particularly, the timing, you will not get real far...about 170-180 with stock ECU on an N/A engine needing 100 oct. (in my opinion, of course).
Going up from there things get exponentially more expensive.
Turbo cars I would think are limited by the intercooler, the ecu, and then just controlling boost and seeing how hard you wanna push your stock rods and bearings. Again, the ECU would make things better.
Get a Walbro 255 in tank pump and it will drop right into the tank with an extra gasket and a spacer ring...should be good for 300hp.
Less bling, more zing.
Nice post Lurch...
Some one who knows the tranny's are strong! Just like I've been telling people.
Lurch, what are your opinion on a new intake manifold. Anythoughts on design or sizes for a FI application. Might be a broad question, but i figure you probally have more experience with this engine than anyone around here. What restrictions does the stock intake manifold have.
