Protege Headlights in a Protege5
Ugly5
Protege5
So I recently bought a 2003 Protege5 from a small used car dealer here in Chicago, and all in all I've been happy. Sure I've had some small issues popping up here and there (CDs stuck in the 6-changer seems to be a common issue).
After driving around for a while at night, I was getting the high beam flash from every other car I passed. It took a little while, but long story short I came to realization that whoever owned the car before me (or the dealer) put protege headlights in place of the Protege5 headlights. Since the P5 lights should have two separate bulbs, I was running nothing but high beams (h4 bulb was installed - high/low beam combo).
I've rewired the harness so I'm always in low beam (and since I live in the city I have little use for the high beam anyway) for the time being. My question is since I'm halfway between two kinds of lights, should I go back to the p5 housing and bulbs, or finish up the wiring job and add my high beams to the Protege housing that's in there?
I kinda like the look as they are, but if anyone has any pros/cons of either I'm all ears.
Cheers
-Ugly
it would be cheaper and easier to just keep the sedan lights, and fabricate a jumper harness.
Sedan lights FTW!
Well I think I found all the harnesses and wiring I need to keep the sedan lights in, with the high beams back in for only $15 shipped so I'll probably go that route. It all rests on my ability to do some tidy soldering, but with that I should have a completely reversable setup.
Cheers
-Ugly
^ Just another company/brand that makes replacement parts. The headlight looks exactly like OEM except it has a the word "Depot" casted into the plastic by all the other words.
