UPDATED!!!
Wire locations pics and a clutch bypass relay diagram has been added.
Wire Codes for All 2001 and up Proteges
- including sedan, MP3, MSP, and P5:
Function, Color, POL, Location
12 Volt, black/white or black, +, Ignition Harness
Starter, black/blue, +, Ignition Harness
Ignition, blue, +, Ignintion Harness
2nd Ignition, black/red, +, Ignition Harness
Accessory, black/white, +, Ignition Harness
Power Lock, lt. green/red, -, Module high in driver kick panel
Power Unlock, same wire as lock
- This is a one wire door lock system. Two signle pole,double through Relays are needed. The diagram is below. Lock requires a 1.5K ohm resistor.
Lock Motor, red, N/A, door lock relay left of brake pedal
Unlock motor, blue, NA, door lock relay left of brake pedal
Disarm Defeat, red/black--------------, N/A, door lock relay left of brake pedal
Parking Lights +, lt. green black, N/A, drivers kick panel(never found) or under dash in a large harness (picture below)
Parking Lights -, brown, N/A, Head Light switch
Headlights, red/yellow, -, headlight switch
Door Trigger, black/blue, -, drivers kick panel
Dome Supervision, use door trigger
Trunk / Hatch Pin, red/green, -, at light in trunk
Factory Alarm Arm, N/A
Factory Alarm Disarm, N/A
Tachometer, purple/white, N/A, Diagnostic Connector in driver side rear corner of the engine compartment also on ECM pin 48
Speed Sensor aka VSS, orange or green/red (Confirmed as violet/red on a 2003 P5 by shareef777) , N/A, pin 58 on ECM
Brake Wire, green/yellow, +, brake switch
Horn Trigger, black/red, -, Steering Column
Wipers, blue/white(L) or blue/red(H), +, steering column
LF Window Up/Down, red/black - yellow/green, A, Drivers door switch
RF Window Up/Down, green/white - lt. green/black, A, Drivers door switch or kick panel
LR Window Up/Down, red/green - yellow/red, A, Drivers door switch or kick panel
RR Window Up/Down, blue/white - green/red, A, Drivers door switch
For Standards!
Neutral safety trigger, pink green, - (while in neutral), Under battery tray from transmission.
- Its actualy in a two wire harness attached to a bracket that is on the transmission. However, the battery must be removed to have working room to get to the neutral safety wire.
Clutch Bypass Realy Wiring for DEi alarm/remote starters:
note: There are 2 clutch switch harnesses. Use the 12 gauge wires from the back of the clutch pedal, not the small wire from the front harness.
Wire Locations:
Door Trigger
http://www.msprotege.com/members/1sty/remote%20starter/Door%20trigger.JPG
Ignition Harness
http://www.msprotege.com/members/1sty/remote%20starter/ignition%20harness.JPG
Lock Wire
http://www.msprotege.com/members/1sty/remote%20starter/Lcok%20Wire.JPG
Parking Lights Wire
http://www.msprotege.com/members/1sty/remote%20starter/Parking%20Light%20wire.JPG
Tach Wire
http://www.msprotege.com/members/1sty/remote%20starter/Tach.JPG
Link to Turbo timer install "How To"
- Credit to Orangeappeal for this gents!
- Turbo Timer How To
Wire colors for all cars
http://www.bulldogsecurity.com
These guys have a good list of alot of cars wire colors.
Always verify the colors with a mutimeter!
Thanks for the information. It is quite helpful.
