Snow Tire Rim Size?
So if I start phoning around to wreckers for rims, do I ask the guy for, 14" (5x4.5/5x114.3), hub bore 67.1mm, +35 offset? Are Eclipse the only ones in this size or can I get the black steelies in this size?
Sorry for the knob question but I lost 4 days pay this winter due to snow, so I want to get rims before next winter and be better prepared.
I was able to source the steelies from a local junkyard for $100. When looking for wheels in any size 14"-18" remember our bolt pattern is 5x4.5/5x114.3 and the desired hub bore is 67.1mm. The other deciding factor is the offset which will change depending on what size wheel you are looking at.
For 14's you should be good with a +35 offset ('93 Eclipse, what I have) on a 14x5.5 wheel. I'm not really sure what the desired offset for 15's would be.
