Ceasar1010
- Mazdaspeed Protege 2003 and Miata STO 1997
Ok so I got an ODBII reader and these are the codes I got
I tried to start it with the MAF disconnected, remebered and this is what i got. It still stutters in idle, like something didnt fire, when I accelerate and then push the clutch in the RPM dips real low and almost dies. If I push the gas in neutral the rpms go to 1400 for about3 seconds and then down to about 800 rpm.
My boost guage says -12 (Vaccum leak from what I have read in the forums- everyone says theres is at -20psi) The common thing they all say accept for P0301 is Vaccum leak.
I got the diagram for testing the coil from the forums and I will try that for the P0301. Can I swap the two coils to see if the error moves? If it moves its the coil , if it dosnt move its the plug / wire?
I cleared all the codes and will drive to work tomorrow. Probably about 60 miles. I want to see if these repeat themselves.
Thank you for the help anyone can give me.
Update: the boost guage says -12 vac at idle.
- P0301 - Cylinder #1 Misfire
- P0506 - Idle Air Control System RPM Lower Than Expected
- P0171 - System Too Lean (Bank 1)
