problem with the brakes....
nadzi
soo i went out the other day and baught myself rotours for my car, had some fun trying to get the bracket for the caliper off finally managed to do that and replaced the rotours on the front. now the issue iim having is that when i drive on the high way or at high speeds, i step on the brakes and the car like moves to the right just a little but still does it and kinda weird, anyways i thought i shouldnt have to bleed them but i did anyways, as i was bleeding them i came across a weird suction noise coming from the left front drivers side, only heard when the brakes are applied and the suction is heard both wayswhen pushed in and out, ive checked that there is no fluid leaking... what could be the problem?(boom06)
problem solved!! :) thank you for the reply tho i dont know how but somehow when i was putting the brakes back togeather again after replacing the rotours i guess the spring pushed it out of place and it was kinda diagonal in the brake pad housing and it was like sideways so i put new brake pads on seeing as the other one was bent and mangled and everything is working fine now!:)
