Pro Kit pricing?
Rally
Mazda, 3, 2.3
Hey guys, how much if i buy a pro kit, i no about $220 but how about installation and allignment
You will not need a camber kit but I advise it.
Price with alignment? varies between shops. look for the lowest price install and alignment. Springs aren't hard at all to install yourself. just need patience a full day and spring compressors.
I got sportlines and installed them my self... saved about 200+(from what I was quoted)
It was actually very easy to install.
Id say sport lines as well since I run them too. BUT pro kit if you don't wanna scrap;)
yea thinkin probly go with pro kit. And i tried installing exhasut but failed haha so ill probly just have the same shop do it. And ill probly get camber kit eventually just will wait it out haha. THanks for info
If you are paying a shop to do the installation and alignment you might as well get the camber kit at the same time. Otherwise you are going to have to pay them again to install it and realign your car down the road. Just my $0.02.
I believe that you will see excessive wear on the inner shoulder of your rear tires even with the drop of the Pro-Kit. I can't say for sure because I'm using the H&R Sport springs and my rear camber is at -2.5ish. However, after I installed my Koni Sports I was on stock springs for a while and I cut down the bumpstops which allowed the rear of the car to sit lower and even with that small decrease in ride height I saw more wear on the inner shoulder of my winter tires. YMMV of course.
And FWIW, an alignment will probably cost you anywhere from $60-100. I recently had it done and it cost me around $90 with tax and everything.
