Power windows 2 sec delay
Int3grity
07 Cx-7 Liquid Platinum
Has anyone figured out how to sucessfully disable the 2 sec delay when rolling down the windows I keep practicing the how to as per vehicle owners manual and no luck I am stuck with this. 3-36 in your vehicle owners guide
Yes people my car has a 2 second delay(Two step Process) come on now it clearly states even in the picture disable 2 step process
if your battery trminals are disconnected this is what happens at least according to mazda, it can happen also with ecu update. either way this feature was not on untill the ecu update. I can roll down the windows but it's delayed by 2 seconds.
The windows would roll down about an inch stop and then proceed to roll down it's like a safety issue thing.
2Sec delay=Two step Process
I believe you but I haven't rolled down my windows -- still too damn cold out. :eek:
i followed the steps and succesfully disabled the 2 second delay
you have to turn the key to ON, not ACC and don't forget to push the button to the bottom, release, do it again, release, pull to the top, release, pull again, release, then turn key to off, then repeat procedure. immediately you can verify if procedure was succesful :D
Yo you got this to work on both windows with no probs or just one?
did you check 5 min later to see if it remained? cause this thing has fooled me a few times where it appears to work then 5 min later back to the 2 sec delay
