Our 2008 CX-9 is starting to show its age. I replaced the driver's door regulator a few months ago. This morning, the wife couldn't get the passenger front window to roll back up. It would go up a few inches, then go back down. The happened with both switches and when holding the switch or on auto. I had to pull up on the window while she held the switch up to keep it closed.
So, what could be the issue? We are set to get rain this week, so I would like to fix it soon. I can order another motor/regulator off of Rockauto again and replace it. But, some minor internet research says disconnecting the battery for a few seconds and reconnecting it fixes it. The issue is related to the anti-pinch feature. The wife won't be home until after work, so I can't test out the latter solution. I'd rather not have to order the part if a simple power rest would fix it.
Has anyone experienced this issue and figured out how to fix it?
