C
cougfan99
140hp isn't that bad, but it seems like the problem is that not enough power is getting to the wheels of our car. So I'm thinking of putting on the cams, switching to a light weight flywheel, and replacing the tires (when worn)and with significantly lighter Z rated ones. The cams produce less friction, the flywheel is easier to spin (8lb vs. 20lb) and the tire combination is easier to turn (can drop 20lb between both fronts). This should put more hp to the wheels and produce quicker acceleration; also should increase mpg since it'll be running more efficiently but not putting extra fuel into the engine. You guys think it's worth it?
