Antoine said:Good thread topic...Let's keep the posts civil and on topic...Thanks!
Da 6 said:Alot of us haven't found a use for that center vent. Some use it to warm the shifter knob. Another place us non speed 6ers placed the pod was the center of the dash where navi would go. there is a 3 gauge pod floating around for the mazda 6. second I find a local vender I'll share the info(Pict Borrowed from blackmajic)
jecoy said:Here's my gauge shot guys, it might give other people some ideas, took me 1 1/2 to do it but worth it.
MAZDASPEED619 said:here's mine...
I'd love to adapt that to my Nav door with all electronic gauges for oil temp, boost and oil pressure. No need to look at gauges if you're using Nav, no need to look at Nav if you need the guages....bonesmp5 said:Here ya go --- second one down, hope this helps -- unless you all ready got it --
http://www.gaugepods.com/mazda.html
The gauge is a 45mm Omori Boost Gauge. It has a multi color back light (blue,green,red) fine tune the colors and you can match the MS6's lights....Bigg Tim said:Yeah, that looks pretty good, do you have any daytime shots? What kind of gauge is that? It matches pretty well.
The DEFI BF gauge matches perfect, but 200+ for the gauge and another 150 or so for the link controller is a bit too steep.
Bigg Tim said:What did you do to block off the air from teh back of the gauge? how did you route the wire, down through the ducting?
jdub260 said:I love this idea but...do you have a how to that you could post to the "How To.." section on the install?? I don't know the first thing about adding a boost gauge so a how to would be great.
jrodhotrod said:I have been wondering what to do about this myself with this car.
In my protege I had the full pillar pod and the custom cluster for holding 5 round gauges. I added a digital EGT because I had no clean place to put another round gauge.
I love the Defi BF gauges, but the cost is prohibitive and the lack of clean places to put gauges in the 6 is a problem. This time around I am looking at a Boost gauge and maybe a wideband and EGT eventually if I do start to mod it more heavily, but everything else will likely be passed on.
With that said, the Omori is at the top of my list for it's small size and convenient mounting location. Also on my list is this handy gauge which is going to be very flexible when it comes to mounting:
http://www.dynotunenitrous.com/store/scripts/prodView.asp?idproduct=131
I had their Digital EGT and was very happy with it. I am just not sure if I want a digital boost gauge, it's not as easy to read as a traditional dial.
M6GR8 said:Just like to show how I did mine.
BTW, they are boost, oil pressure, oil temp.
