Hi fellas, this is my Mod list until today 02-16-2009. Currently boosting 26 PSI on Methanol Injection 474.8whp & 390 lbs torque
1. Honed and polished engine block.
2. Blue printed and balance engine
3. Sandblasted and black powder coated engine block.
4. Crankshaft balanced and polished.
5. Aries custom forged pistons low compression 8.5:1.
6. Pauter forged chromolly rods.
7. Clevite 77 Main bearing set.
8. Clevite 77 Thrust washer set.
9. Clevite 77 Connecting rod bearing.
10. Cometic .078" Custom made thick head gasket. (Lowered engine compression from 8.5:1 to aprox 7.8:1 to run more boost safely)
11. Goodyear timing belt.
12. TBK Performance custom Stage 3 FS-DE head blue printed and balanced.
13. TBK Performance custom turbo dual overhead cams.
14. TBK Performance 5 angle valve job.
15. TBK Performance full head port and polish job.
16. Ferrea 1mm bigger titanium valves & harder valve springs & Titanium Retainers.
17. ARP head studs, ARP washers, ARP nuts.
18. SR adjustable cam gears.
19. ProtegeGarage intake manifold single Runners with TBK Performance port & polish job.
20. TBK Performance port & polish throttle body job to 60mm.
21. Throttle body coolant bypass.
22. Unorthodox ultra light S under drive pulley.
23. Gates high performance engine belts.
24. Apex air diversion plate.
25. Mazda Millennia supercharged PCV valve.
26. Maxspeed magnetic oil drain plug.
27. Corksport Hi Performance 52mm Aluminum Radiator.
28. Spal Slim Line dual 13" Hi Performance Fans.
29. Mazdaspeed 1.3 bar radiator cap.
30. Mazdaspeed JDM B-Spec low temp thermostat.
31. Mazdaspeed gunmetal oil cap.
32. AWR 70a bushings front motor mount.
33. AWR 70a bushings rear motor mount.
34. AWR 70a bushings transmission mount.
35. SLS-Performance Racing Passenger Side Motor Mount.
36. Weapon R engine damper.
37. AEM water/methanol injection kit with 1 gallon tank.
38. Dual Walbo 255 in-tank and in-line fuel pumps.
39. RC 1000cc high impedance injectors.
40. Perrin fuel rail.
41. Haltech E6X stand alone engine management air/fuel, timing, launch control and anti-lag.
42. Haltech 3 bar MAP sensor.
43. Haltech Sequential shift light.
44. HKS Super Sequential V2 blow off valve.
45. HKS earth ground cables system.
46. Mazdaspeed positive charging and voltage stabilizer.
47. AEM 4” inlet cone filter with Injen water repellant pre-filter (blue)
48. Spearco front mount intercooler.
49. TBK Performance custom chrome 3 front mount intercooler pipes & flanges.
50. Turbonectics clamps.
51. Hiboost GT35 big turbo manifold + TBK Performance port & polish job.
52. Garrett GT3582R turbo with stainless steel water and oil lines.
53. TBK Performance 3custom downpipe.
54. TBK Performance custom 3 downpipe back exhaust with 3 Resonator.
55. HKS Hi-Power muffler chrome.
56. Tial 40mm external chrome wastegate.
57. NGK Laser Iridium sparkplugs (one step colder).
58. Haltech coil packs.
59. K&N 1008 oil filter.
60. Royal Purple 20w50 fully synthetic engine oil.
61. Lucas synthetic oil stabilizer & protection (new engine formula).
Drivetrain:
62. Complete transmission internals cryo treated.
63. Fidanza 7.5 lbs flywheel.
64. DSS Level-2 drive axles.
65. ACT street performance clutch.
66. ACT extreme pressure plate.
67. Welded LSD front and back of it with cryo treatment.
68. Racing synchronizers with cryo treatment.
69. TBK Performance custom 600whp 3rd, 4th, gears with cryo treatment.
70. Techa-Fit clutch line.
71. Redline shockproof synchromesh heavy-duty transmission synthetic oil.
72. TWM short throw shifter.
73. TWM shifter bushings.
74. CorkSport Bronze Oil Bushings.
Brakes:
72. Brembo cross drilled & slotted rotors.
73. Techa-Fit stainless steel brake lines.
74. Posi-Quiet ceramic low dust brake pads.
75. Royal Purple synthetic brake fluid.
Suspension:
76. TEIN adjustable superstreet coilover suspension
77. GT-Spec front strut tower brace.
78. GT-Spec 4 Point front lower ladder brace.
79. GT-Spec Front lower tie brace.
80. Corksport Pedders Front Suspension Arm Bushing Kit.
81. Racing Beat front lower sway bar.
82. AWR front lower sway bar bushings.
83. AWR adjustable front end links.
84. GT-Spec rear strut tower brace.
85. GT-Spec rear full trunk cage.
86. Racing Beat rear lower sway bar.
87. AWR rear lower sway bar bushings.
88. AWR adjustable rear end links.
89. GT-Spec rear trailing link set.
90. GT-Spec Rear lower reinforcement panel.
91. GT-Spec Rear lower reinforcement V-brace.
Electronics & Interior Accessories:
92. OEM Mazdaspeed classic soft trim 2 tone leather interior dark charcoal with titanium gray + titanium gray leather door panels.
93. Greddy Profec E-01 (silver)
94. Greddy Profec B Spec-II electronic boost controller (silver).
95. Greddy remote switching system steering wheel (silver).
96. Greddy full auto turbo timer (silver).
97. Maxspeed engine start bottom (blue).
98. Auto Meter triple gauge pod (black).
99. AEM Uego 6 in 1 wideband controller (white).
100. Auto Meter C2 Indi glow pyrometer EGT 0-1600 degrees F.
101. Auto Meter C2 Indi glow 30 P.S.I boost/vacuum gauge (white).
102. MRYELLERMP5 custom bezel dual gauge pod.
103. Auto Meter C2 Indi glow oil pressure gauge 0-100 psi (white).
104. Auto Meter C2 Indi glow fuel pressure gauge 0-100 psi (white).
105. Maxspeed cluster Indi glow gauges 7 colors with dimmer (white).
106. DaveB cluster polish rings.
107. Maxspeed chrome cluster bezel.
108. Mazdaspeed seat belts pads.
109. Clifford alarm.
110. Lo-Jack satellite security system.
Audio & Video
111. Kenwood MP919 head unit cd/mp3/Sirius satellite radio/with IPod interface controller.
112. 7" widescreen in dash DVD-player & TV tuner NTSC/PAL.
113. Apple IPod 160GB video.
114. Kenwood PS400M 1400 watts mono amplifier 1 ohm stable.
115. Power Acoustic 3 fared capacitor.
116. Kenwood PS300M 600 watts 3 channel amplifier.
117. Kenwood 8 Band Electronic Equalizer.
118. Kenwood 6 Way Electronic Crossover.
119. Kenwood titanium tweeters (6 tweeters).
120. Cerwin-Vega HD series 4-way front doors speakers.
121. Cerwin-Vega HD series 4 way rear doors speakers.
122. Cerwin-Vega HD Series 4 way 6x9 rear upper deck speakers.
123. Cerwin-Vega V-Max 12 dvc subwoofers 400 watts rms (2 12 subs).
124. Rockford Fosgate 12 dvc subwoofers 600 watts rms (2 12subs).
Lighting:
125. Euro black smoked head lights.
126. Bi-XENON head lights kit. 8000k high & low beams.
127. Piaa clear rectangular fog lights.
128. XENON 8000k H3 fog lights kit.
129. Lexus IS350 L.E.D ultra white license plate bulbs.
130. Mazdaspeed carbon fiber license plate frame.
131. OPTX MultiColor L.E.D Undercar KIT by ( StreetGlow )
Wheels & Tires:
132. 2006 Mazda RX-8 shinka edition wheels 18 X 8.
133. Nankang ultra sport NS-II 215/35/18 tires
134. Nitrogen on tires
135. Gorilla chrome wheel nuts.
136. Gorilla chrome wheel locks.
Coming up next mods list:
137. 505zoom Intake Manifold along with Vibrant Vaccum distribution block
138. Spec 6.8 Lbs lightweight aluminum flywheel.
Near Future and final mods list 2009-1010:
139. Rotora 4 piston big brake kit in RED, + Custom Rear Big Brake Kit with E-Brake option as well
140. Quaife LSD differential G-type mazdaspeed protg.
141. Quaife differential bolt kit mazdaspeed protg.
142. PAR Engineer DOG BOX Transmission with Straight Cut Gears and Tranny case reinforcement with longer final Gear Ratio
143. AWR Deep sump oil pan protg.
144. DOC-B Upgraded Hi performance Engine Oil Pump System
145. ProtegeGarage Engine oil cooler
146. Transmission oil cooler
147. Digital tire monitoring system tire pressure/temperature
