plug bolt size for rear caliper adjustment screw
BlueBomber
03 P5, 5-SPD
the title says it all - anybody know the bolt type/size for the "plug" bolt that hides the adjustment screw for the rear brake calipers?
it's part number 26-700 (26700)
If it were me,.. I'd take the bolt from the other side (assuming you have it) to a hardware store and match it up.
I only know it'll be metric but it's not a critical part... (just a plug like you said)
The bolt that hides the adjustment screw i believe is a 14mm or 9/16st I just changed the calipers on my p5 a couple months ago. edit: The adjustment screw under the bolt is an allen key, not sure what size thou. only tighten enough till disc/rotor can still rotate. do not over tighten.
Sent from my SGH-I337M using Tapatalk
