Please Help:
sp33d03
03.5' mazdaspeed protege
I have a 03 speed protege.. does anyone have a problem when they are driving, and when they come to bumps, does it seem like the tire is rubbing on the wheel well? Cause when i hit a hard bump nothin happens, but when im just normally driving it seems to happen. Has this happened to anyone before? and pointers or anything? Thanks (shrug)
Are you lowered or stock suspension? You could be hearing the "clunk" from the swaybar bushings.
i did, i think i may have the problem most of the guys on this site are having. EIther i should check out my strut tower, bushings on my sway bar, and grease them up. It sounds like that wheel well is hitting, but i may have mistaken it as a "clunk" warranty is still good so maybe ill take it back to the dealership, but idk what to tell them, and how they could check it out.
Just go in and tell them you hear a clunk or rubbing noise when you go over bumps. There is a TSB out on our bushings anyway. they'll know what youre talking about.
