I e-mailed Corksport asking about the FS-ZE piston set and the difference between that and their Mazdaspeed piston set for our engines. Here's what I learned about the pistons:
The FS-ZE piston set (also made by Mazdaspeed!) uses a 10.4:1 compression ratio
The aftermarket Mazdaspeed piston set advertised on their site uses a 10.7:1 compression ratio. I assume that would give more power!
Our stock compression is 9.1:1 (if I remember correctly).
I have e-mailed them again asking whether I would need anything else changed to compensate for the pistons to maintain the reliability of the car, and I'm waiting for a reply.
Now my question is: do higher compression pistons improve torque and hp all over the powerband, or is it just at the top like cams? Since I plan to do cams as well, I'd rather not lose any more low end than is absolutely necessary when modding, to maintain the daily driveability of the car.
On to cams:
Corksport tells me that the FS-ZE engine uses the same exhaust camshaft as the FS engine, and hence all Proteges have the same exhaust cam. The one advertised on the Mazda Motorsports site (with the unground lobes) is a race cam, and they did not recommend it for a street vehicle.
However, there is a Mazdaspeed exhaust cam at Corksport that is for our FS engine, and they tell me that it would be a good upgrade when switching to the FS-ZE intake cam (which would be especially good for us MP3's because we have the double runner intake manifold).
I've also asked them whether I'd need any additional mods to make them work properly ie. stiffer valve springs to prevent float and as above, I'm waiting for a reply.
If anybody knows any more info, please let me know! Just an FYI...happy modding!
On to cams:
