Mental Addiction
Banned
Wiggles422 said:I mean no disrespect, but shouldn't the kit come larger diameter exhaust? I mean 2.5" piping for 350hp seems restricting.
You can make over 350WHP with 2.5" DP.
However a 3" would make more power.
The GT3071 and GT3037 both use a .63 AR 4bolt T3 housing.The housing will not except anything bigger than a 2.5" due to the bolt holes being in the way.Next issue is the lower radiator hose and thermostat.The 3" will bring the downpipe out 1" more in radius and then going to a V-band setup will add an extra 2".So we are working on a new lower radiator hose setup inorder to make room for the 3" DP.
