PIAA fog lamps install?
  • Thread starter Thread starter Mac Daddy
  • Start date Start date
Mac Daddy
Has anyone done a replacement of the factory fog lamps to the PIAA? Any information on how-to would be greatly appreciated.
I thought about it, but I decided not to due to cost (I wanted their HID foglamps). I am running their Xtreme bulbs in the factory for lamp housings. After some slight re-aiming I am very happy with the results.
to install the PIAA bulbs in the fog lamps it took me about one and a half hours, its a real hard job at first, but once you get the hang of the first side, the other side is all that much easier...you ahve to unscrew the plastic screws on the back side of the bumber right in front of the wheel, and from there you can get access to the fog lamp and then you can unscrew it, take it out from the front (still attached to the wiring) and replace the bulbs and do everything backwards....its easier than it sounds, you just have to play around with it for a little while....goodluck...hope they dont burn out cause its sooo annoying to do it all over again... Rachel Ley is awesome!!
Well, I know someone did the replacement of the whole assembly; but I cannot find the thread.
crazy32184,
oops nevermind, you changed bulbs, and not the lamp it self.. I'm planning to change the whole lamp but trying to figure out a good way to mount them..
RC
I got them already, but also trying to find a good way of installing them.
Mac Daddy,
There is a way to mount PIAA 40 Round Driving lights. Just wait
around a bit. Kartboy will have them for you. Look at my Sig for
the updated picture. So you can easly put PIAA lights on your car.
Hope this helps.
RC
Similar Threads and Articles
