Perrin Rear Sway Bar = Possible Clunk Fix?
Bhamsan
2004 SSM Acura RSX
I remember asking this a while back in the Perrin threads and didn't get a response. Has anyone ordered/installed a Perrin rear sway bar yet? Any Pics out there possibly? Cullen, have you received these in stock yet? My clunk is starting to give me a headache, and I'm thinking that if this does what I think it does, it will fix the clunk. Let me know your opinions people, since I couldn't get the right info before, and I just now remembered a few weeks later.
Theres no pics of it yet because its not out perrin is still working on it.
Why is it for sale at **********.com then if it is not out? Is there an expected due date for this part?
http://www.**********.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=SU&Product_Code=PMP-SUS-200&Category_Code=MSPSUSP
I believe this is the link should be looking at! (bike)
Yeah I saw that already. So they're not out yet or what? It looks like I can order it right now.
Check the Delsing product - I've had 'em on for ~9000 miles and no clunk yet. The urethane bushings'll squeak without lube, but keep em lubed and it's silent as a church mouse so far. Search on my name and you'll find a bunch of threads - and I profit not a bit by giving this little "endorsement" other than having tested the bushing relocation brackets for Micaspeed - just letting folks know.
There's apparently a cheap fix in the form of getting the Energy Suspension commercial urethane bushings and trimming/bending brackets to fit, but I haven't seen it in person - check the clunk threads on the MP3 boards.
I'd rather have something that fixes the clunk AND improves my handling, which I am guessing this might do if it relocates the bushings.
Check the threads - the handling is better, but it's an "incremental" better, not a wholesale "holy cow" better. Feels more direct, less of a move-then-take-a-set action and more of a smooth progressive rotation. Rear end is more planted, and a little stiffer but not enough for me to be able to coax it into big oversteer or anything like that. No clunk after ~9k but as I said the urethane bushings WILL squeak (they all do) but if you get the zerked kind you can lube 'em and shut 'em up. Note squeak does not equal "clunk" and the squeak starts gradually so you have some time to turn up the radio and get home to lube 'em, and the bushings are commercially available and maybe $15-$20 to replace if you need to. Oh - and you can lube with a small grease gun without jacking it up, just reach under, undo the zerk cap, attach the greasegun, squeeze 2-3x, remove and replace the cap. If you're anal about it, you can wipe down the bar when you're done. That's it - done in a shorter time than it takes to explain.
I've said it before so I'll bother to type it in again - it's like rotating a ballpoint pen by bending the pocket clip out at a 90 degree angle and pushing on it. Hold the pen in the middle and you get what the stock centrally located bushings are trying to do - the pen both rotates and tries to "bend" at the bushing. Move your fingers to just at the base of the clip and push on the end - see how the pen wants to rotate and not deflect? That's what the bushing relocation does.
OK, enough for me!
OK, enough for me!
I read it over about 5 times and I still can't quite see what you're trying to do. I get the 90degree bend part on the clip, but as far as where you're pushing and where you're not, I don't get it.
Obiviously if it is for sale NOW, then it is out. Would be my first guess. (flame)
