I am trying to locate the pins on the PCM or perhaps BCM for the VSS (vehicle Speed Sensor) and the RPM/PPM for engine speed in order to wire up a HUD with speed and tach (Defi VSD-X). I have the service manual and the wiring diagram but as luck would have it those two pins are not specifically defined. No luck with getting help direct from Mazda or dealer so far...
I will post when I find out but hoped someone here might know or have a better resource then I...
Cheers
On edit: Update. So as it turns out (not unexpected) the '08 , which I have, is significantly different from the '07 (my manuals are for '07 doh!) and my local service center (very helpfull BTW) says I will just have to wait till the '08 manuals are in and they promised to help at that time...sigh.
Mods? Can you add a question mark to title please? Sorry
Cheers
