does anyone know if the ms3 and mz3 use the same passenger side motor mount???
if i buy an aftermarket one for an ms3, will it fit and work on my mz3??
They are not the same.
MS3 mount is a bit larger and has a bolted on weight ballast. To get the MS3 passenger side mount to fit into my 05 MZ3 sedan I had to take off the ballast. 2x 8mm or 10mm bolts and away you go.
Interesting fact is the MS3 mount that I got does not have any FoMoCo designations on it.
