P5 pedals
rjmhotrod
'02 P5 White
Are these the stock P5 pedals? One of the two lower screws on the gas pedal came out. I tried to put it back in but the aluminum pedal and the actual pedal underneath are not the same size. The screw holes in the aluminum are out past the edges of the pedal underneath. Plus the lower screws are a different mount than any of the other screws or pedals. It appears that the screws on the bottom don't appear to attach the aluminum to the actual pedal. I found the screw and the nut that came off and I proceeded to take the other screw off to see if I could figure it out. Am I crazy, stupid or am I just missing something (such as my mind)?
mountjonas said:
those aren't the stock pedal covers.
Thanks mountjonas. I bought the car used from a dealer and it had these pedal covers on it. I've never seen pics of the stock pedals so I was unsure. They're good performance mods though. These and a turbonator and I probably would be up to about 175-180hp. (wiggle)
don't forget the stickers! those will easily put you in the 300 hp range on stock internals.
our pedals just have the rubber covers on them. except for the gas. i think that's plastic...i think.
yeah, a turbonator bolted to the pedals = major power! (second)
