Smitty's MSP
- 03.5 MSP Titanium Grey
Alright, I've been searching and searching, losing sleep, and paranoid driving has pushed me to the point of almost insanity. There was a time that I used to get on the forums to gawk over the awesome msps on here, now I spend my days pursuing this white whale of a problem, I'll list out my symptoms:
First is the CEL, which I can't seem to find an answer to, Intake Manifold Runner Control Stuck Closed Bank 1 (3rd time It's thrown this code)
Boost/vac gauge just recently installed violently rattles between 0-2 under WOT, idles at about 18 mmHg, deceleration is closer to 21 mmHg
Turbo response was delayed until about 4500-5000 rpm, but after the CEL was thrown today, no spool up whatsoever anymore
I feel as though the Idle is rough, kinda like the car is vibrating too much (also could be because we've never changed the motor mounts)
Probably most importantly, I'm very slowly losing oil... only place I could find any trace was on the metal line under the turbo, but when I tried tightening the bolt, it wouldn't turn
What we've done to the car so far (and I'm listing EVERYTHING so you guys know):
Clunk Fix Bracket, much needed and solved the terrible squeaking
Water pump, oil pump and head gasket replaced by mazda
Injen CAI (as I'm typing maybe I should clean the Intake and/or MAF?)
Replaced the Hot pipe (rupture on the line going to the BPV) with a SAMCO silicone one
Replaced Alternator (twice, and it should be noted that my car ran with a cap and a 500W amp for a week solely on my yellow top optima)
And just put in the Forge Wastegate and Forge Bypass valve with a vac/boost gauge
Could be some things I'm forgetting, and I'm hoping it something easy, but my gut tells me I'm getting into something very deep here. Any comments and suggestions help, If not It looks like I need to find a good mechanic around Columbia (I DON'T want to take it to Mazda again, nothin but trouble everytime I go in)
