- 2016 CX-5 GT AWD
I've seen a few other posts addressing the P0882 error code, I thought I'd add what just happened to me.
Cold morning, about 25F, car kept in garage. Drove down the mountain about 10 miles, then the dash board looked like Apollo 13 after the cryo stir. Power steering failed briefly, music from phone via Bluetooth connection failed, error messages I couldn't read appeared. I was able to pull over and turn off the car. Tried to start... Nothing. Tried again... Nothing. Gave it a couple minutes and tried to start, success, but no Nav screen. Made it to my destination, all the time thinking of what to do. I had to play my softball game (I'm first base, they need me.) After the game started the car, Nav screen woke up, the only thing left was the check engine light. Made a stop for an errand. Back to the car, started it, check engine light disappeared. Everything now appears as though nothing had happened. I got home, all the time thinking it must be a power issue. Plugged in the scanner and found the P0882 code. Opened the hood and looked at the battery. The negative post/terminal was clean and tight. I then flipped up the cover on the positive side, the blue/green corrosion was impressive. I spent about 20 minutes cleaning all the gunk and making a good connection between the post and connector. I'm hoping that was the issue. I will check the other ends of ground and power cables when I can, but I hope I'm good.
Thanks for reading.
Thanks for reading.
