So, got this code on my Automatic P5.
I can't find very much info on it. This thread seams to be the most detailed...
https://www.mazdas247.com/forum/showthread.php?123826886-Neutral-safety-switch-trouble-shooting
But the links to the pics are dead and that is a manual.
Is the Neutral Safety switch the same thing as the Transaxke Range Switch?
Service manual lists these possible causes...
TR switch malfunction
Short to power between TR switch terminal C and PCM terminal 32
Short to power between TR switch terminal G and PCM terminal 6
Short to power between TR switch terminal F and PCM terminal 9
Short to power between TR switch terminal E and PCM terminal 7
Damaged connector between TR switch and PCM
PCM malfunction
Is the PCM near the OBDII port?
Any detailed advice on troubleshooting?
PCM malfunction
