Options for subwoofer with Bose system?
2016 Mazda CX-5 GT AWD w/Tech & i-Activesense
So I've been enjoying my GT with Bose for the most part but I miss my 8" sub that I had in my protege5. The Bose system sounds better then the p5 ever did (factory speakers and head unit) but the low end really is lacking. I've considered adding a subwoofer if some sort and maybe replacing the dash speakers to something with a tweeter like the polk db351 or the infinity reference ones. Any how, seeing as I'm now in my 30's with a wife and two young children the time for 12" monsters with huge Amps is past. What would be a sensible way to fill in the lows without shaking the car apart? I've been thinking of picking up one of those Bose spare tire subs off eBay and seeing if that could work. I figure the mazda6 and cx-3 have them, maybe it would be enough? The other thought would be doing one of those powered subs like the kenwood KSC-SW11 and installing under one of the seats. Would that even be able to be hooked up? And the last but no doubt the most expensive would be to fiberglass a box into the rear hatch side panel and use an 8" sub and amp installed somewhere. I made my box for my protege but don't really want to go thru that all again so I'd get a shop to do it. How much do you think that would cost?
The shop that made my box charged about 300 or 400 for it I think.. if you get a cutout in the OEM trim (should be space) I'm guessing around $300.. Although TBH if you were going that route all you are really doing is cutting the hole, then you can just pay for the install if you don't want to wire it.
Well I don't really want to be cutting into anything if I can avoid it. I'd really like it to be something that is heard not seen. That's why I was thinking of the spare tire sub. Under the floor, out of sight. Does the mazda6 have enough base from their sub? Would it be difficult to adapt to the CX-5 system? The powered sub seems like a good option as well. Amazon has that kenwood on sale for about $150. I like the idea of it since its all in one, amp and speaker and should fit under the seat. Doing a box would work but it would be expensive. I'm thinking all told it would come out to at least $600-$800 for the build and equipment. $300-$400 for the box to built and $300-$400 for the sub, amp, and wiring kits. I don't think I can convince my wife to let me drop that much for a sub.
As anyone used or installed one of those powered subs? How do you like them, are they enough to fill in the low ends?
Do, what I did.
Get a MDF from Home Depot(12"x12"), cut off the inner corners(to fit), cut a hole for the sub and for the wire connector.
Install the sub + wire connector.
You will need to put something, that would cover the wheel mounting holes and bolt it down with a hex head screw.
Strap the MDF down, with two straps to the spare wheel and you are done.
You will still need an amp, though.
I'm using a JL Audio 10" shallow sub.
https://drive.google.com/file/d/0B17P1WKnh15MRF9WYmZISDUxSHM/view?usp=sharing
11-speaker Bose in Mazda6 doesn't have subwoofer, but has two additional tweeters otherwise the speaker setup is the same as CX-5 Bose system. 7-speaker Bose in CX-3 does have a spare-tire subwoofer and tweeters. I was thinking getting a CX-3 Bose subwoofer but it'd be very expensive. May be you should take a look at JL Audio MicroSub where V8toilet highly recommended.
A member sent me a private message asking some advise so I shared my thoughts and what I have done with my CX5 Sport and CX5 Touring. I decided to share that response here on this thread in case it might help someone else. I have also installed Damplifier sound deadening from the rear foot wells all the way back to the rear hatch and on all four doors, which made a 3 db reduction in noise when measured with a Radio Shack sound meter. Below is what I wrote.
There are a few things you can do depending on the level of sound quality you prefer. The simplest thing to do is to NOT replace the factory radio but just upgrade some or all of your speakers. The first CX5 I purchased was a 2013 Sport with the basic radio and 4 speaker system. I added some Pioneer TS-T110 7/8-Inch Hard-Dome Tweeters to the front dash under the left and right grilles, which adds clarity and dimension to the system. They were at the time ~ $30 for a pair. I was very happy at the time with just the added tweeters as an upgrade.
You can also change out the door speakers for new two or three way coaxial door speakers for an even greater improvement in sound quality, but you have to choose wisely here because the factory radio doesn't have much power. You want to choose a 6.5" or 6.75" coaxial speakers with an efficiency or sensitivity rating greater than 90, but this can vary a little. The sensitivity rating tells you how efficiently speakers convert power into sound. The higher the number, the louder the speakers will play. An efficient speaker helps you maximize your available power. Some great speakers for this are the Pioneer TS-A1675R three ways or the Alpine SPS-610 Type S 6-3/4" 2-way car speakers. The Alpine are slightly higher end speakers and may need an amplifier to sound the best. My wife currently has the 6x8 Pioneer 3 way coaxial speakers in her Mazda 5, which sounds pretty good on the factory radio, soon to be ungraded this weekend with a Sony single din radio and class D amplifier. For higher end brands look at the Alpine type R and X, Pioneer Premier, and Focal. The Nakamichi NSE65 seem like promising less expensive but good sounding coaxial speakers based on reviews.
You can replace the factory radio, but this is where things get expensive and complicated. For the 2016 CX5 as you mentioned, you will likely lose the commander control knob in the center consol. Crutchfield can advise you on this and they are a fantastic car audio retailer. They have the most generous return policy and great tech support and they ship fast. The CX5 dash accepts what they call double din radios, which come in touch screen versions and regular old fashion push button radios with a LCD screen. These will give you the best sound quality and options. If you decide to go this route than you will need a touch screen CD or DVD double din radio so that you can retain the backup camera function. The great thing about Crutchfield is that they tell you what fits your CX5 and with what adapters you will need. They will also provide you with customized installation instructions tailored for you vehicle. They back this all up with real knowledgeable tech support over the phone to help you every step of the way. The best head units out there are made by Alpine, Kenwood Exelon, Pioneer, and I think Sony has come a long way too. Look for features such as 4 channel preamp outputs with at least 4 volts (2V is just ok) and subwoofer preamp outputs so that you have more options for upgrading in the future.
With factory radios becoming more and more integrated into other automobile systems, there is a growing segment dedicated to factory radio improvement. Companies such as Audio Controls have some pretty slick and simple devices that you add to your factory radio to allow you to upgrade them with amplifiers and adjust them with equalizers and time alignment. They can also compensate for things like bass roll off, which is common on factory radios to protect the paper cone speakers. In my CX5 I added an Audio Controls DQ-61, which allowed me to add a Pioneer 4 channel Premier stage 4 amplifier with 75 watts per a channel. I upgraded the front speakers with Polk Audio (I do not recommend them) components with a crossover and the rears with Polk coaxial speakers, all 6.5. I purchased a JL Audio CP108LG-W3v3 micro sub and this is powered with a very old 23 year old Alpine amplifier, which still out performs many amplifiers made today. With the DQ-61 I am able to fine tune the system and use the time alignment feature to adjust speaker outputs so that they all reach my ears at the same time. This time alignment is something I never thought would be so great; it makes a big difference. There are adapters that you can buy that make wiring these things into your factory harness almost plug and play so that you do not have to cut any factory wires.
The last thing I want to emphasize is the importance of a subwoofer. A subwoofer will add a new dimension to your system. It adds that depth and punch that makes listening to music enjoyable. In my opinion JL Audio subwoofers are by far the best subwoofers for the money on the market. I like the micro sub because its small and relatively light for its size and it puts out tremendous high quality bass for just being an 8 subwoofer in a tiny box. I like it too because when I want it out of the way I just unplug it and remove it with ease.
If you do not want to spend a lot of money than I recommend that you keep your factory radio and upgrade the speakers. Purchase an Alpine KTP-445U Power Pack class D amplifier, which you can fit behind your radio to power the door speakers. Purchase an add an amp adapter http://www.ebay.com/itm/Mazda-Stere...ash=item1c52768815:g:GYoAAOSwPe1T76mU&vxp=mtr or audio controls LC8 converter with some plug and play wiring harnesses and add a JL Audio micro sub with a built in amplifier such as this http://www.jlaudio.com/car-audio-subwoofer-systems-amplified-microsub
I do now find after driving my Infiniti for a couple weeks that it's Bose 10 speaker "Studio on Wheels" system with subwoofer does sound better than unit in CX-5. Nothing I am going to swap anything out for but compared side by side the G's is better IMO.
Not sure if you're interested in making your own box, but I just finished mine. I took photos from start to finish. 8" Rockford Punch P1S2 (chosen for the small sealed enclosure volume specs) along with a small Kenwood mono amp. Total cost including the sub, amp, custom enclosure materials, etc was a little over $200, and the whole project from start to installation took two days. Here's a photo of the finished subwoofer before wiring to the amp:
A bit over $200, not too bad Mikey. How's the sound coming?
New Threads
