Oil & Water line lengths
Rogue
Red 5 Standing by
Contributor
2003 MSP
I need to order my oil and water lines before I start my install. I don't know how to measure how long I'm going to need. So I'm asking how long everyone else has used.
I'll be using the stock MSP exhaust manifold and s-pipe with a GT28R turbo.
Anymore info you need?
*subscribes because I'll need the same info soon* I'm collecting parts for my build much faster than I thought :)
If you're patient and watch ebay like a hawk, you can usually get the lines in the lengths you're looking for relatively cheap. As for quality concerns, I've been using the nascar ebay lines on a project car, and have no complaints.
viral_override said:
I have about 2 ft .... ish for each... the longest length will be from the oil pan to the turbo...
would that be 2ft for each of the 4 lines?
Kansei, i was thinking of getting them from www.atpturbo.com
I know i need ss lines for the oil, but what about the water? will rubber lines be ok? or should i know ss with those, too?
ok, so 1ft for water to and from the turbo. 2ft for oil to the turbo, and another 2ft from the turbo to the oil pan.
Questions:
Where do i tap/tee to get oil to the turbo?
What kind of fitting do i need for the oil return line?
Is the fitting on my turbo -3 or -4? [see pics]
Thanks brian for that writeup.. although it makes it seem like quite the project argh. I was hoping it was just an oil pan thing so I could buy a spare pan and tap it. rats.
I'm doing the same with my oil line return location while my engine is being built. No more questionable oil pan return location.
I can arange that you get the TAP for that size and drill..
The location of the hole is not important in the crank cradle (Windage Tray) I just seleced the middle..
You can do that, many people do it but make GD sure that there is a good seal. Like Mr Gasket, silicon (Black) washers, O-Rings in any combination. If you weld it, it will probably still leak onless you are like Jesus with a TIG...
Oil has an interesting way of "Weaping" out of things..
Thanks but my shop is looking after this for me. All is good. :)
Questions:
Rouge,
My only concern with this is that I don't see a restrictor for the oil flow. The Ball Bearing turbos don't require as much oil as the journal/fluid bearing turbos. Too much flow will blow the oil seals.
Here is an example of a fitting with at restrictor built-in:
Click Here
LinuxRacr said:
Rouge,
Click Here
So ball bearing turbos don't thrash the oil nearly as much?
