Maxx Mazda
Contributor
- Stock P5
I just pre-assembled my Spool kit (T3, Spool Mani, TIAL 38mm gate) and noticed that the way it's setup, the oil return line is on top. Have a look at the pic. The oil feed line (small one) is on the bottom. Shouldn't this be reversed so that gravity helps pull the oil out of the turbo, back into the pan?Or does the incoming fresh oil push the old oil up and out of the return? Does this seem right? Also, I just have the feed line screwed into the oil feed port, and not using the flange. As long as I seal it with teflon, it should remain leak free, correct? Or need I use the flange?
