Oil level question
2021 CX-9
Checked the oil and it was at the minimum mark. Assumed that meant 1 qt low. Apparently not as I am now overfilled. What problems am I causing? Being in the middle of the service interval I think I’ll drain and refill but not change the filter until the planned interval, about another 2k.
Oil level slightly over the maximum mark probably wouldn’t hurt anything. Oil level well above that mark could cause a problem.
Nothing wrong with draining some/all of the oil out and refilling to the proper level. If you change your own oil, you could just do a full oil service. If not, I see nothing wrong with leaving the filter alone until the next scheduled service.
Where is the oil level at on the dipstick? be sure to take the reading at least 5 mins after engine shut off.
If it's just slightly above the max mark, I wouldn't worry too much about it. If it's like an inch or more, I'd probably do a drain and fill just to be safe.
