oil change
uncletime
2007 MS3 GT Black Mica
if anyone has changed their oil on their MS3 themselves can you let me in on the secret to getting the cap for the oil filter off? i tried for a half hr with no luck... i would think it would be hand tight but not really... any help or suggestions would be appreciated
There is a special wrench. It looks like a metal cup with a square drive for a socket ratchet.
can i get that at autozone/ any local auto parts store? you know what kinda price they run?
Best to get it from a Mazda dealer to be sure it fits correctly. There is a vendor on one of the forums that had a deal for 10 filters @ a few $ each, plus a free wrench. Search around and you will probably find it.
Also a tip: There is a plug at the bottom of the filter holder that takes a metric allen wrench. If you open that first and drain the oil out of the filter, it is a lot less messy when you take the filter itself out.
I used a strap-wrench. I did open up the drain plug before loosening the cap. Maybe that made the difference?
I used a strap wrench as well. Worked great.
Does anyone else hate having to remove those damn clip/screws and 8 bolts just to take the splash guard off? LOL
