Frequent Questions
* How Long Do the Emissions Warranties Apply to Individual Parts of My Vehicle?
* How Do I Know Whether I Am Entitled to Coverage Under the Emissions Warranties?
* May I Have My Regular Repair Facility Perform Warranty Repairs?
* Do the Emissions Warranties Apply to Used Vehicles?
* Can Any Portion of An Emissions Warranty Repair Be Charged to Me?
* What Reasons Can the Manufacturer Use to Deny a Warranty Claim?
* What Should I Do If My First Attempt to Obtain Warranty Coverage Is Denied?
* What If the Dealer Claims That My Vehicle Can Pass the I/M Test Without Repair?
* How Can Maintenance Affect My Emission Warranty Coverage?
* Do I Have to Show Any Maintenance Receipts Before I Can Make an Emissions Warranty Claim?
* Are Dealers the Only Persons Allowed to Perform Scheduled Maintenance Recommended by the Manufacturer?
* If I Need Replacement Parts, Must I Use the Vehicle Manufacturer's Parts Only?
* If I Buy a Used Vehicle, How Do I Know Whether It Has Been Maintained According to The Maintenance Schedule?
* How Will I Know If My Claim Has Been Accepted As Valid?
* What Happens If the Manufacturer Does Not Respond to My Performance Warranty Claim Within the 30-Day Deadline?
* What Do I Do If the Manufacturer Will Not Honor What I Believe to Be a Valid Emissions Warranty Claim?
For 1995 and newer model year vehicles, emission control and emission related parts are warranted for the first 2 years or 24,000 miles of vehicle use (whichever first occurs). Specified major emission-control components are warranted for the first 8 years or 80,000 miles of vehicle use (whichever first occurs).
Parts with a stated replacement interval, such as, "replace at 15,000 miles or 12 months," are warranted up to the first replacement point only.
_____________________________________
If you or a qualified automotive technician can show that an emission control or emission related component, or a specified major, emission-control component, is defective, the repair or replacement of the part is probably covered under the Design and Defect warranty. If your vehicle failed a federally approved emissions test and has not exceeded the time and mileage limitations for the Performance warranty, any repairs or adjustments necessary for your vehicle to pass should be covered by the manufacturer if the failure was not caused by improper maintenance or abuse. When you believe you have identified a defective part, or your vehicle fails an emission test, you should follow the procedures for making a warranty claim as identified by the manufacturer in your owner's manual or warranty booklet. When taking your vehicle in to have repairs performed under the Performance Warranty, be sure to have with you a copy of the I/M test report as proof of your emissions test failure.
_______________________________________
If you plan to have the manufacturer pay for a repair under either of the emissions warranties, you must take the vehicle to a facility authorized by the vehicle manufacturer for repair to give them the opportunity to diagnose and repair it. Note that if your regular repair facility is not authorized by the vehicle manufacturer, they are not obligated to advise you of parts that are covered under warranty. Before giving your automotive technician the "go ahead" to perform repairs, check your owner's manual/warranty booklet for possible warranty coverage.
_________________-
Yes. It does not matter if you bought your vehicle new or used from a dealer or anyone else. As long as the vehicle has not exceeded the warranty time or mileage limitations, these warranties apply.
IMPORTANT NOTE: Before buying a used vehicle, be sure that all of the emission control components as originally installed by the manufacturer are present and functioning properly. If emission control components are missing or have been tampered with, or the configuration of the exhaust system has been changed, the emissions warranties on this vehicle may be void. In addition, if you live in an area with an I/M program, the vehicle will probably not pass inspection and you will incur the expense of parts or repairs necessary for the vehicle to pass.
_________________
If you have valid warranty claim, you cannot be charged for any costs associated with the diagnosis or repair of the problem, including labor charges, parts, or miscellaneous items that are necessary to complete the repair. For example, if a manufacturer agrees to replace a catalytic converter under the emissions warranty, you should not be charged for the diagnosis of the bad converter, or any pipes, brackets, adjustments, or labor needed to complete the replacement.
___________________
If your vehicle is within the age and mileage limits for the applicable emissions warranty, the manufacturer can only deny coverage if evidence shows that you have failed to properly maintain and use your vehicle, causing the part or emission test failure. Some examples of misuse and mal-maintenance include the following:
* vehicle abuse such as off-road driving or overloading; or
* tampering with emission control parts or systems, including removal or intentional damage of such parts or systems; or
* improper maintenance, including failure to follow maintenance schedules and instructions specified by manufacturer, or use of replacement parts which are not equivalent to the originally installed parts.
_________________
If your first attempt to receive emissions warranty coverage is denied, you should do the following:
1. Ask for a detailed explanation, in writing as to why emissions warranty coverage was denied; and
2. Ask for the name(s) of the person(s) involved in the decision to deny coverage, including anyone from the manufacturer's regional or zone office; and
3. Ask for the name(s) of the person(s) with the manufacturer you should contact to appeal the denial of coverage under the emissions warranty.
4. Contact and, if necessary, write to the person mentioned above requesting coverage and giving the basis for your request. Repeat and continue the appeal process until you are satisfied or have exhausted all means of appeal.
______________
The law does not require that you fail every I/M test in order to trigger the warranty. If a valid test shows that you have an emission problem or there is a defective part, you should get it fixed, while your vehicle is still within the warranty period. Otherwise, you might fail a future test because of the same problem and have to pay for the repair yourself. If you doubt your original test results or the dealer's results or diagnosis, you can always get another opinion from another dealer or your I/M program.
______________
Performance and the cost of scheduled maintenance are your responsibility. You may either perform scheduled maintenance yourself or have a qualified repair facility perform it for you.
If a part fails as a direct result of your vehicle not being properly maintained or being used in a manner inconsistent with the manufacturer's recommendations, or a part fails as a result of the vehicle being involved in an accident, the manufacturer may not be required to repair or replace the failed part under warranty. For example, failure to replace the spark plugs at the intervals specified in the maintenance schedule can lead to misfiring and eventual damage to your catalytic converter - a very expensive part to replace. If the maintenance is not performed properly as recommended, the manufacturer may deny warranty coverage.
To ensure maximum air pollution reduction from the emission control system, as well as to ensure continued warranty coverage, better gas mileage and performance, and longer vehicle life, you should have all maintenance performed as recommended by the manufacturer's schedule. A list of scheduled maintenance for your vehicle can be found in the owner's manual or warranty booklet.
_________________
No. Proof of maintenance is not required in order to obtain coverage under the emissions warranty if an emission control or emission related component, or a specified major emission control component, is found to be defective in materials or workmanship. However, when it is likely that the lack of proper maintenance has caused the particular part to fail, you may be asked to show that scheduled maintenance was performed.
If you perform scheduled maintenance yourself, you should keep a detailed log of work performed and any receipts for parts purchased to perform the maintenance. In some instances, you may be asked to qualify your ability to perform such maintenance. Vehicles should always be maintained according to manufacturers' specifications.
_____________
No. Scheduled maintenance may be performed by anyone who has the knowledge and ability to perform the maintenance and repair. You may even maintain the vehicle yourself, as long as the maintenance is performed according to the manufacturer's instructions provided with the vehicle.
For your protection, before taking your vehicle to a repair facility to have any maintenance performed, check your maintenance booklet and make a list of the scheduled maintenance to be performed at that time. We suggest that you present this list to your auto technician as opposed to merely asking for a "tune-up" or a "12,000 miles servicing." Your receipt should list all the maintenance performed and should be kept for your records.
If you maintain the vehicle yourself, you should keep receipts for parts and a maintenance log to verify your work.
__________________
No. A manufacturer cannot require the use of any specific brand of parts in the maintenance of your vehicle. However, the manufacturer can require you to use parts that are of equal quality to the original parts.
__________________
The best way to learn whether the vehicle has been maintained according to its schedule is to ask the seller for receipts proving that all of the scheduled maintenance was performed. Having the receipts on hand will provide necessary evidence if the question of maintenance arises when considering repairs under warranty. To prevent any loss of your vehicle's emission performance, you should continue to follow the maintenance schedule in the owner's manual or warranty booklet.
If the seller does not have the owner's manual, warranty booklet or maintenance schedule, you can obtain them from the manufacturer.
________________
After you present your vehicle for a Performance Warranty claim, the manufacturer has 30 days to either repair the vehicle or notify you in writing that the claim has been denied. If you are making a Performance Warranty claim and your I/M program imposes a shorter repair deadline, the manufacturer must meet the deadline. Because of the significance of these deadlines, you should get written verification from the dealer showing that they acknowledge the date by which repairs must be made.
There are no specific requirements for Defect Warranty claims, however, manufacturer responses should be made within a reasonable time period.
______________
You may agree to extend the deadline, or it will be automatically extended if the delay was beyond the control of the manufacturer. Otherwise, a missed deadline means the manufacturer forfeits the right to deny the claim. You may then have the repair performed at a facility of your choice, at the manufacturer's expense. (This requirement only applies to Performance Warranty claims.)
___________________
If you believe the manufacturer has not honored a valid claim and your vehicle has not exceeded the time and mileage limitations, you should contact an authorized warranty representative and follow the procedures outlined in your owner's manual or warranty booklet. If the authorized dealer denies your warranty claim, contact the manufacturer's regional or zone office for further assistance. If you are still not satisfied, follow the appeals procedure outlined in your manual or warranty booklet.
Of course, you are entitled to pursue any independent legal actions you consider appropriate to obtain coverage under the emissions warranties. In addition, the Environmental Protection Agency (EPA) is authorized to investigate the failure of manufacturers to comply with the terms of these warranties. If you have followed the manufacturer's procedures (including those for appeals) for making a warranty claim as set out in your owner's manual or warranty booklet, have received a written denial and you are not satisfied with the manufacturer's determination, you may submit a letter to EPA at the following address. It should provide details of the situation including the basis for the claim, a copy of the written denial, copies of your letters to the manufacturers, and copies of any receipts for emission control parts and repairs you have paid for:
U.S. Environmental Protection Agency
Office of Transportation and Air Quality
Light-Duty Vehicle Group
Attn: Warranty Complaints
2000 Traverwood Drive
Ann Arbor, MI 48105
Other sources of assistance may be your local or State consumer protection agency or office of the Attorney General. You also should be aware that low-cost or free legal assistance may be available through a local legal aid office, the State bar association, or a law school clinic staffed by law students.
In Summary
If an emission control or emission related part, or a specified major emission control component is defective, or if your vehicle fails an I/M test, and your vehicle is within the time and mileage limitations for emissions warranty coverage:
* Present a warranty claim to an authorized warranty representative.
* If your warranty claim is denied:
* Ask for the reason for denial, in writing.
* Follow the appeal procedures in your owner's manual.
* If you are not satisfied with the manufacturer's decision:
* Contact the EPA, which will investigate the denial of a valid emissions warranty complaint.
* Keep This With Your Vehicle for Future Reference.
For More Information
For further information on emissions warranties, please contact John LaCroix at:
Ann Arbor, MI 48105
Telephone: 734-214-4463
