Now using the MAP sensor..
Status
Not open for further replies.
I just hope we all can now get past anymore MPI bashing from people and some mods[not you Pat] who just did not want to see that facts for what they are or maybe for their own screwed up reasons. Like I have stated 100s of times before. If your s*** is not right you cannot tune for it no matter what system you have. Now you still are not done. You have injectors to clean for one. Then you need to retune your car with the MAF or the Worlds best O2 tuner to get it 100% once and for all.
Get some flux, that will help the solder get sucked in also. Remember, you don't want the glob of solder, you want to see the strands somewhat so you know you have good penetration.
MPNick on the ignition timing bar on the MPI software, is that reading actual timing? B/c his software is saying it has full bar of timing at idle and it is saying under throttle its pulling timing. His PDA dyno says otherwise through his obd2 scan port. I think something maybe wrong with the ignition set up? Also, how/why did the analog map come up with a bunch of trash values after loading a map? because the MAF isnt hooked up.
The ignition tab is more or less then the stock values, so a -4 is 4 degree's retarded off the stock timing. How is the computer communicating, USB or serial. Is the battery strong in the car, maybe that's causing an issue. Is is a map that you've used before?
i wanted to add this
MAP SENSOR BAR vs VOLTAGE
Yea i set the values i had working pretty good on another car and used the fuel and timing #s that worked on patricks old maps. Let me take a screen shot and highlight what im talking about. Its not on the ignition tab. I'm talkin about the bars on the left side of the screen.
MPNick said:
Sure you know all. Thats why people running race fuel and upto 20psi on this forum make no where near that much power.
Like who?
We never ran big boost, what do you not understand. Plus we had 8 degrees over the stock timing removed.
And how much timing would have been pulled if you ran on pump gas? If 116 octane fuel isn't so great, then why did Dean run it? And why did he blow a piston while using 93/94 octane the day after the dyno using the same tune map that he ran on C16? Reason is, that the car was tuned so aggressively that you couldn't run it on pump gas, but you could do it on C16.
Thats fine, we will just wait and see what te deal is at the next dyno day. Maybe you can reach 265 this time, maybe?
Hopefully.
At this point in time I only find you to be a foolish. I have lost any and all respect for you, both as a Mod and a person.
Super. What's any of this have to do with me being a moderator?
Keep your daytime job because you do not understand all that is needed for tuning.
Nor do you. You're the guy who told me I should be running a 12:1 AFR while off of boost. I let you tune my car for 5 minutes after we installed the MPI, and it ran like utter crap. You're the guy who I had to EXPLAIN WHY ALL DYNO SHEETS MUST CROSS AT 5252. You did not even understand how horespower was calculated. So while there are pleny of things you do know about cars, there's a lot that you don't. You yourself don't understand all that is needed for tuning.
You know, I'm getting sick of your attitude, Nick. I try to be a nice guy and you keep taking stabs at me. For the last time, I am not, nor have I ever bashed the MPI. Besides, what are my "screwed up reasons" for "bashing the MPI"? This oughtta be funny. I like to tune it a different way than you. Get over it, already.
Kooldino said:
Like who?
We had planned to run high boost but never got past 15psi because of the spark problem. So we never tuned it for higher boost. He then rased the boost to 24psi and ran out of C116 and installed Exxon 93.
Now we did you break your piston at 250whp, if the MAP is so great for adding fuel? I never see a aftemarket piston fail at suck a low power level in my life.
12 to 1, please so me where I ever posted tat you should ran 12 to 1 off of boost?
Yes I do not know all, I tell everyone one that. I screw up and learn almost everyday.
MPNick said:
Kooldino said:
Like who?
Ok, wait...he couldn't make it past 15psi due to the spark issue, so he turned it up another 9psi to 24psi? Does that not make sense to anyone else but me?
I assume you mean "why" did I break my piston at 250whp? Well, firstly, I obviously had more than 250whp at the time. Secondly, it wasn't a fuel issue. I added fuel with my extra injectors, just like Dean did. So what if I didn't eek every last drop of fuel from my stock injectors? Lastly, I think it was spark related. The MAP adds fuel fine. But these coils have trouble sparking in the cold for whatever reason. Once it dipped below 45* or so, the car didn't spark the same. Apparently I'm not the only one with this problem.
We were in my car. I told you that it felt odd around 2500rpm, so you started to add fuel down low, off of boost. I asked you why you were doing it and you said "it needs more fuel to make power". Then you went on explaining how a "modern head design needs more fuel to run properly", etc. So I gave you the benefit of the doubt and let you do what you wanted. When you were done, the car had the worst tune in it that I have ever run.
Then don't blame me for not "knowing it all" either.
MPNick said:
Keep in mind that you were not turbocharged stock. So your AFR needs to be tuned for idle and none boost. This is why you need to dump the map. You can tune the O2 with the MPI tuner [look under the worlds best O2 clamp thread] or you need to tune it with the MAF.
In my own personal case, I used to run a perfect 14.7:1 AFR from the second I turned the key when I had an FMU. I didn't start running lean at idle until I added the MPI. I reckon Linux is in the same boat as me. Don't try to blame it on the fact that he's not MAF tuning.
Perhaps the resistance that the MPI adds when you wire it in is enough at a low RPM to lean it out a tad (until you blip the throttle and it relearns)?
Anyway, Linux, I pulled a degree or two of timing at idle and it fixed me up pretty good.
Status
