North America - Mazda2 Engine/Transmission Wiki?
Richard_rsp
Contributor
2016 Scion iA
Is there something that you would like to add? Please respond below or PM me and I will gladly edit this first post to reflect any data that is shared...
Contributing Members: lovmyrx7, Richard_rsp
*PLEASE CONSULT MAZDA DIRECTLY OR A FACTORY SERVICE MANUAL BEFORE RELYING ON THESE SPECIFICATIONS. THESE ARE FOR CASUAL INFORMATION PURPOSES ONLY.*
ENGINE
MZR Z-series (ZY-VE)
1.5L (1498cc)
Horsepower: 100 HP @ 6000rpm
Torque: 98 lb-ft @ 4000rpm
Bore: 78 mm
Stroke: 78.4 mm
Compression ratio 10.0:1
Head Material: Aluminum alloy
Block Material: Aluminum alloy
LUBRICATION SYSTEM
Force-fed type
Engine oil specification -
Engine oil viscosity: 0W-20
Oil pressure (reference value) [Oil temperature: 100C (212F)]
330380 kPa (3.373.87 kgf/cm2, 47.955.1 psi)
@ 3,000 RPMs
Oil pump - Trochoid gear type
Oil filter - Full-flow, paper element
Bypass pressure: 78118 kPa (0.801.20 kgf/cm2, 12.017.1 psi)
Oil capacity (approx. quantity)
Total (dry engine): 4.4 US qt (4.2L , 3.7 Imp Qt.)
Oil replacement: 3.9 US qt (3.7 L, 3.3 Imp Qt.)
Oil and oil filter replacement: 4.1 US qt (3.9 L, 3.4 Imp Qt.)
COOLING SYSTEM
Type - Water-cooled, Electromotive
Coolant capacity (approx. quantity)
MTX: 5.4 US Qt (5.1 L, 4.5 Imp Qt.)
ATX: 5.7 US Qt (5.4 L, 4.8 Imp Qt.)
Water pump - Centrifugal, V-ribbed belt-driven
Thermostat - Wax, bottom-bypass
Opening temperature: 8084 C (176183F )
Full-open temperature: 95 C (203F )
Full-open lift: 8.5mm (0.33 in) or more
Radiator - Corrugated fin
Cooling system cap
Cap valve opening pressure: 93.2122.6 kPa (0.9511.250 kgf/cm2, 13.617.7 psi )
Cooling fan - Electric, 5 Blades
Outer diameter: 320mm (12.6in)
Cooling fan motor output: 120w
Valvetrain: Chain driven duel overhead cam, 4 valves per cylinder with Variable Valve Timing (VVT)
VALVE TIMING
Intake -
Open, BTDC (), -931
Close, ABDC (), 5919
Exhaust -
Open, BBDC (), 40
Close, ATDC (), -1
VALVE CLEARANCE:
Intake -
0.270.33mm (0.01070.0129in)
[Engine cold]
Exhaust -
Ignition: Direct coil-on-plug, w/ platinum tipped spark plugs
IGNITION SYSTEM
Ignition system: SEI
Electronic Spark advance
Firing order: 1342 (all cylinders independent firing)
Spark plug Type: ZJ46 18 110, ZJY6 18 110
STARTING SYSTEM
Starter: Coaxial reduction
Output (kW)
MTX: 1.0
ATX: 1.4
Fuel Injection: Electronically Controlled, Multiport Fuel Injection
FUEL SYSTEM
Injector -
Hi-ohmic, Top-feed, Voltage driven
Pressure regulator -
Regulating pressure: approx. 390 kPa (3.97 kgf/cm2, 56.5psi)
Fuel tank -
Capacity: 11.3 US gal (42.8 L, 9.4 Imp gal)
EMISSION SYSTEM
Catalyst: WU-TWC (monolith)
Evaporative emission control system: Charcoal canister type
PCV system: Closed type
ENGINE CONTROL SYSTEM
Neutral switch (MTX): ON/OFF
CPP switch (MTX): ON/OFF
ECT sensor No.1, No.2: Thermistor
IAT sensor: Thermistor
PCM temperature sensor: Thermistor
CKP sensor: GMR element
CMP sensor: GMR element
TP sensor: Hall element
APP sensor: Hall element
Variable tumble shutter valve position sensor: Hall element
MAF sensor: Hot-wire
A/F sensor: Zirconia element (All-range)
HO2S: Zirconia element (Stoichiometric)
MAP sensor: Piezoelectric element
KS: Piezoelectric element
BARO sensor: Piezoelectric element
Fuel tank pressure sensor: Piezoelectric element
Fuel type -
Fuel Octane Rating (Anti-knock index)
Regular unleaded fuel
87 [(R+M)/2 method] or above (91 RON or above)
TRANSMISSIONS
4-speed Automatic Electronically Controlled Overdrive [FN4A-EL]
Gear ratios
1st - 2.816
2nd - 1.553
3rd - 1.000
4th (O/D) - 0.695
Reverse - 2.279
Final gear ratio - 4.147
AT Fluid
Mazda Genuine ATF M-V
Capacity (approx. quantity)
7.4 US qt. (7.0 L, 6.2 Imp Qt.)
Torque converter stall torque ratio: 2.19
Hydraulic system
(Number of drive/driven gear plates)
Forward clutch: 4/4
3-4 clutch: 3/3
Reverse clutch: 2/2
Low and reverse brake: 4/6
Band servo
Servo diameter (Piston outer dia.)
64.6mm (2.54 in)
Front planetary gear(Number of teeth)
Front sun gear: 49
Front pinion gear: 20
Front internal gear: 89
Rear planetary gear (Number of teeth)
Rear sun gear: 43
Rear pinion gear: 27
Rear internal gear: 98
Primary gear (number of teeth): 86
Secondary gear (number of teeth): 82
Output gear (number of teeth): 20
Ring gear (number of teeth): 87
Automatic Transaxle Shift Mechanism
Cable Operated, Floor-shift
5-Speed Manual (w/ OD) [F35M-R]
Shift assist
Forward: Synchromesh
Reverse: Selective sliding and synchromesh
Gear ratio
1st - 3.416
2nd - 1.842
3rd - 1.290
4th - 0.972
5th - 0.775
Reverse - 3.214
Final gear ratio - 3.850
Manual transaxle oil
Grade: API service GL-4
Viscosity: SAE 75W-80
Capacity (approx. quantity):
3.07 US qt (2.91 L, 2.56 Imp qt)
Clutch
Hydraulic Clutch control
Clutch fluid: SAE J1703 or FMVSS116 DOT-3
Clutch pedal: Suspended
Pedal ratio: 5.54
Full stroke: 125mm (4.92 in)
Clutch master cylinder inner diameter: 15.87mm (0.6248 in)
Clutch release cylinder inner diameter: 19.05 mm (0.7500in)
Clutch cover
Spring type: Diaphragm
Set load: 4315 N (440.0 kgf, 970.1lbf)
Clutch disc
Outer diameter: 190mm (7.48 in)
Inner diameter: 132mm (5.20 in)
Manual Transaxle Shift Mechanism
Cable Operated, Floor Shift
*PLEASE CONSULT MAZDA DIRECTLY OR A FACTORY SERVICE MANUAL BEFORE RELYING ON THESE SPECIFICATIONS. THESE ARE FOR CASUAL INFORMATION PURPOSES ONLY. *
Hi Richard,
By any chance have you run across pics of the exhaust side of the motor?
I'd like to see how the exhaust manifold is configured.
Thanks,
John
2011 - Mazda2 - Engine
ENGINE SPECIFICATIONS
Specification
Item
Specifications
MECHANICAL
Cylinder arrangement and number
In-line, 4‐cylinder
Combustion chamber
Pentroof
Valve system
DOHC, timing chain driven, 16 valves
Displacement
(ml {cc, cu in})
1,498
{1,498, 91.4}
Bore stroke
(mm {in})
78.0 78.4
{3.07 3.09}
Compression ratio
10.0:1
Compression pressure
(kPa {kgf/cm2, psi} [rpm])
1,520
{15.50, 220.5} [300]
Valve timing
IN
Open
BTDC ()
-931
Close
ABDC ()
5919
EX
Open
BBDC ()
40
Close
ATDC ()
-1
Valve clearance
IN
(mm {in})
0.270.33
{0.01070.0129}
[Engine cold]
EX
LUBRICATION SYSTEM
Type
Force-fed type
[Oil temperature: 100C {212F}]
330380
{3.373.87, 47.955.1}
[3,000]
Oil pump
Type
Trochoid gear type
Oil filter
Type
Bypass pressure
(kPa {kgf/cm2, psi})
78118 {0.801.20, 12.017.1}
Total (dry engine)
(L {US qt, lmp qt})
4.2 {4.4, 3.7}
Oil replacement
(L {US qt, lmp qt})
3.7 {3.9, 3.3}
(L {US qt, lmp qt})
3.9 {4.1, 3.4}
COOLING SYSTEM
Type
(L {US qt, lmp qt})
MTX: 5.1 {5.4, 4.5}
ATX: 5.4 {5.7, 4.8}
Water pump
Thermostat
Type
Wax, bottom-bypass
Opening temperature
(C {F})
8084 {176183}
(C {F})
95 {203}
Full-open lift
(mm {in})
8.5 {0.33} or more
Radiator
Type
Corrugated fin
Cooling system cap
93.2122.6 {0.9511.250, 13.617.7}
Cooling fan
Type
Electric
Number of blades
5
Outer diameter
(mm {in})
320 {12.6}
(W)
120
FUEL SYSTEM
Injector
Type
Hi-ohmic
Type of fuel delivery
Top-feed
Type of drive
Voltage
Pressure regulator
Regulating pressure
approx. 390 {3.97, 56.5}
Fuel tank
Capacity
(L {US gal, lmp gal})
42.8 {11.3, 9.41}
EMISSION SYSTEM
Catalyst
Type
WU-TWC (monolith)
Type
PCV system
Type
Closed type
CHARGING SYSTEM
Battery
Voltage
(V)
12
Type and capacity
(5-hour rate)
(Ah)
50D23L (48), 75D23L (52)
Generator
Output
(V-A)
12-90
Regulated voltage
Controlled by PCM
Self diagnosis function
IGNITION SYSTEM
Ignition system
Type
SEI
Spark advance
Electronic
Firing order
Spark plug
Type
STARTING SYSTEM
Starter
Type
Coaxial reduction
Output
(kW)
MTX: 1.0
ATX: 1.4
ON/OFF
CPP switch (MTX)
ON/OFF
Thermistor
IAT sensor
Thermistor
Thermistor
CKP sensor
GMR element
CMP sensor
GMR element
TP sensor
Hall element
APP sensor
Hall element
Hall element
MAF sensor
Hot-wire
A/F sensor
HO2S
MAP sensor
KS
BARO sensor
Fuel type
Fuel
Engine oil grade
0W-20
2011 - Mazda2 - Transmission/Transaxle
TRANSMISSION/TRANSAXLE SPECIFICATIONS
Clutch [F35M-R]
Item
Specification
Engine type
MZR 1.5
Clutch control
Hydraulic
Clutch fluid
Clutch pedal
Type
Suspended
Pedal ratio
5.54
Full stroke
(mm {in})
125 {4.92}
(mm {in})
15.87 {0.6248}
(mm {in})
19.05 {0.7500}
Clutch cover
Spring type
Diaphragm
Set load
(N {kgf, lbf})
4315 {440.0, 970.1}
Clutch disc
Outer diameter
(mm {in})
190 {7.48}
Inner diameter
(mm {in})
132 {5.20}
Manual Transaxle [F35M-R]
Item
Specification
Engine type
MZR 1.5
Shift assist
Forward
Synchromesh
Reverse
Gear ratio
1GR
3.416
2GR
1.842
3GR
1.290
4GR
0.972
5GR
0.775
Reverse
3.214
Final gear ratio
3.850
Grade
API service GL-4
Viscosity
SAE 75W-80
Capacity
(approx. quantity)
(L {US qt, Imp qt})
2.91 {3.07, 2.56}
Manual Transaxle Shift Mechanism [F35M-R]
Item
Specification
Transaxle control
Floor-shift
Operation system
Cable
Automatic Transaxle [FN4A-EL]
Item
Specification
Engine type
MZR 1.5
Gear ratio
1GR
2.816
2GR
1.553
3GR
1.000
O/D
0.695
Reverse
2.279
Final gear ratio
4.147
ATF
Type
Capacity
(approx. quantity)
(L {US qt, Imp qt})
7.0 {7.4, 6.2}
2.19
Hydraulic system
Forward clutch
4/4
3-4 clutch
3/3
Reverse clutch
2/2
4/6
Band servo
Servo diameter
(Piston outer dia.)
(mm {in})
64.6 {2.54}
(Number of teeth)
Front sun gear
49
Front pinion gear
20
Front internal gear
89
Rear planetary gear
(Number of teeth)
Rear sun gear
43
Rear pinion gear
27
Rear internal gear
98
86
82
20
87
Automatic Transaxle Shift Mechanism [FN4A-EL]
Item
Specification
Transaxle control
Floor-shift
Operation system
Cable
Answers some of your questions...I can clean this up and get it stick-ied if dessirable...
If you need questions answered, PM me, and I'll see what I can do ;)
^ Awesome! Thank you! And Yes, if you want to clean it up (or I can), I will edit the first post to reflect the new data so it can be permanent info on the forum! Thanks again!
Edit: Updated! Thank you again!
If there are format issues that you see, please let me know...
If you'd like to, go right ahead. I'm just here to provide information, you can make it look as "purdy" as you'd like :) Just make sure we get some credit! lol.
Thanks Guys,
Lovmyrx7, got any pics of the back of the engine so I can see the exhaust manifold configuration? Also, do the auto and manual transmissions have different ring and pinion gears with different ratios? If so, I wonder if they interchange?
Much appreciated,
John
since there are no push rods, i assumed that the con rods are the only rods in the engine. ;)
Using keyword "Rod" @ Mazda EPC2
oh, yes, i'm definitely talking about PN 66-934. ;)
I'll try to find it if nobody knows.
Quick question, is the U.S. 1.5 an interference engine? I know it shouldn't be an issue since it has a timing chain instead of a belt but I'm curious.
My understanding is that it's more likely an engine is an interference if it *does* have a timing chain...if having the timing go off can cause your engine to blow up, you'd want to use the most reliable linkage possible.
It's a safe assumption that it is an interference engine. Just about any engine made these days will destroy valves if the cams are far enough off.
I'm curious about your curiosity.
