- 2016 Scion iA
North America - Mazda2 Engine/Transmission Wiki
Is there something that you would like to add? Please respond below or PM me and I will gladly edit this first post to reflect any data that is shared...
Contributing Members: lovmyrx7, Richard_rsp
*PLEASE CONSULT MAZDA DIRECTLY OR A FACTORY SERVICE MANUAL BEFORE RELYING ON THESE SPECIFICATIONS. THESE ARE FOR CASUAL INFORMATION PURPOSES ONLY.*
ENGINE
MZR Z-series (ZY-VE)
1.5L (1498cc)
Horsepower: 100 HP @ 6000rpm
Torque: 98 lb-ft @ 4000rpm
Bore: 78 mm
Stroke: 78.4 mm
Compression ratio 10.0:1
Head Material: Aluminum alloy
Block Material: Aluminum alloy
LUBRICATION SYSTEM
Force-fed type
Engine oil specification -
Engine oil viscosity: 0W-20
Oil pressure (reference value) [Oil temperature: 100C (212F)]
330380 kPa (3.373.87 kgf/cm2, 47.955.1 psi)
@ 3,000 RPMs
Oil pump - Trochoid gear type
Oil filter - Full-flow, paper element
Bypass pressure: 78118 kPa (0.801.20 kgf/cm2, 12.017.1 psi)
Oil capacity (approx. quantity)
Total (dry engine): 4.4 US qt (4.2L , 3.7 Imp Qt.)
Oil replacement: 3.9 US qt (3.7 L, 3.3 Imp Qt.)
Oil and oil filter replacement: 4.1 US qt (3.9 L, 3.4 Imp Qt.)
COOLING SYSTEM
Type - Water-cooled, Electromotive
Coolant capacity (approx. quantity)
MTX: 5.4 US Qt (5.1 L, 4.5 Imp Qt.)
ATX: 5.7 US Qt (5.4 L, 4.8 Imp Qt.)
Water pump - Centrifugal, V-ribbed belt-driven
Thermostat - Wax, bottom-bypass
Opening temperature: 8084 C (176183F )
Full-open temperature: 95 C (203F )
Full-open lift: 8.5mm (0.33 in) or more
Radiator - Corrugated fin
Cooling system cap
Cap valve opening pressure: 93.2122.6 kPa (0.9511.250 kgf/cm2, 13.617.7 psi )
Cooling fan - Electric, 5 Blades
Outer diameter: 320mm (12.6in)
Cooling fan motor output: 120w
Valvetrain: Chain driven duel overhead cam, 4 valves per cylinder with Variable Valve Timing (VVT)
VALVE TIMING
Intake -
Open, BTDC (), -931
Close, ABDC (), 5919
Exhaust -
Open, BBDC (), 40
Close, ATDC (), -1
VALVE CLEARANCE:
Intake -
0.270.33mm (0.01070.0129in)
[Engine cold]
Exhaust -
Ignition: Direct coil-on-plug, w/ platinum tipped spark plugs
IGNITION SYSTEM
Ignition system: SEI
Electronic Spark advance
Firing order: 1342 (all cylinders independent firing)
Spark plug Type: ZJ46 18 110, ZJY6 18 110
STARTING SYSTEM
Starter: Coaxial reduction
Output (kW)
MTX: 1.0
ATX: 1.4
Fuel Injection: Electronically Controlled, Multiport Fuel Injection
FUEL SYSTEM
Injector -
Hi-ohmic, Top-feed, Voltage driven
Pressure regulator -
Regulating pressure: approx. 390 kPa (3.97 kgf/cm2, 56.5psi)
Fuel tank -
Capacity: 11.3 US gal (42.8 L, 9.4 Imp gal)
EMISSION SYSTEM
Catalyst: WU-TWC (monolith)
Evaporative emission control system: Charcoal canister type
PCV system: Closed type
ENGINE CONTROL SYSTEM
Neutral switch (MTX): ON/OFF
CPP switch (MTX): ON/OFF
ECT sensor No.1, No.2: Thermistor
IAT sensor: Thermistor
PCM temperature sensor: Thermistor
CKP sensor: GMR element
CMP sensor: GMR element
TP sensor: Hall element
APP sensor: Hall element
Variable tumble shutter valve position sensor: Hall element
MAF sensor: Hot-wire
A/F sensor: Zirconia element (All-range)
HO2S: Zirconia element (Stoichiometric)
MAP sensor: Piezoelectric element
KS: Piezoelectric element
BARO sensor: Piezoelectric element
Fuel tank pressure sensor: Piezoelectric element
Fuel type -
Fuel Octane Rating (Anti-knock index)
Regular unleaded fuel
87 [(R+M)/2 method] or above (91 RON or above)
TRANSMISSIONS
4-speed Automatic Electronically Controlled Overdrive [FN4A-EL]
Gear ratios
1st - 2.816
2nd - 1.553
3rd - 1.000
4th (O/D) - 0.695
Reverse - 2.279
Final gear ratio - 4.147
AT Fluid
Mazda Genuine ATF M-V
Capacity (approx. quantity)
7.4 US qt. (7.0 L, 6.2 Imp Qt.)
Torque converter stall torque ratio: 2.19
Hydraulic system
(Number of drive/driven gear plates)
Forward clutch: 4/4
3-4 clutch: 3/3
Reverse clutch: 2/2
Low and reverse brake: 4/6
Band servo
Servo diameter (Piston outer dia.)
64.6mm (2.54 in)
Front planetary gear(Number of teeth)
Front sun gear: 49
Front pinion gear: 20
Front internal gear: 89
Rear planetary gear (Number of teeth)
Rear sun gear: 43
Rear pinion gear: 27
Rear internal gear: 98
Primary gear (number of teeth): 86
Secondary gear (number of teeth): 82
Output gear (number of teeth): 20
Ring gear (number of teeth): 87
Automatic Transaxle Shift Mechanism
Cable Operated, Floor-shift
5-Speed Manual (w/ OD) [F35M-R]
Shift assist
Forward: Synchromesh
Reverse: Selective sliding and synchromesh
Gear ratio
1st - 3.416
2nd - 1.842
3rd - 1.290
4th - 0.972
5th - 0.775
Reverse - 3.214
Final gear ratio - 3.850
Manual transaxle oil
Grade: API service GL-4
Viscosity: SAE 75W-80
Capacity (approx. quantity):
3.07 US qt (2.91 L, 2.56 Imp qt)
Clutch
Hydraulic Clutch control
Clutch fluid: SAE J1703 or FMVSS116 DOT-3
Clutch pedal: Suspended
Pedal ratio: 5.54
Full stroke: 125mm (4.92 in)
Clutch master cylinder inner diameter: 15.87mm (0.6248 in)
Clutch release cylinder inner diameter: 19.05 mm (0.7500in)
Clutch cover
Spring type: Diaphragm
Set load: 4315 N (440.0 kgf, 970.1lbf)
Clutch disc
Outer diameter: 190mm (7.48 in)
Inner diameter: 132mm (5.20 in)
Manual Transaxle Shift Mechanism
Cable Operated, Floor Shift
*PLEASE CONSULT MAZDA DIRECTLY OR A FACTORY SERVICE MANUAL BEFORE RELYING ON THESE SPECIFICATIONS. THESE ARE FOR CASUAL INFORMATION PURPOSES ONLY. *
ENGINE
1.5L (1498cc)
Bore: 78 mm
Stroke: 78.4 mm
LUBRICATION SYSTEM
Force-fed type
@ 3,000 RPMs
COOLING SYSTEM
Cooling system cap
VALVE TIMING
Intake -
Open, BTDC (), -931
Exhaust -
Open, BBDC (), 40
Close, ATDC (), -1
VALVE CLEARANCE:
Intake -
[Engine cold]
Exhaust -
IGNITION SYSTEM
STARTING SYSTEM
Output (kW)
MTX: 1.0
ATX: 1.4
FUEL SYSTEM
Injector -
Fuel tank -
EMISSION SYSTEM
Fuel type -
TRANSMISSIONS
Gear ratios
1st - 2.816
2nd - 1.553
3rd - 1.000
4th (O/D) - 0.695
Reverse - 2.279
AT Fluid
Hydraulic system
Forward clutch: 4/4
3-4 clutch: 3/3
Reverse clutch: 2/2
Band servo
64.6mm (2.54 in)
Front sun gear: 49
Rear sun gear: 43
Shift assist
Gear ratio
1st - 3.416
2nd - 1.842
3rd - 1.290
4th - 0.972
5th - 0.775
Reverse - 3.214
Clutch
Pedal ratio: 5.54
Clutch cover
Clutch disc
 Just make sure we get some credit! lol.
